Question about Whirlpool Dishwashers
Why no no high pressure wash in whirpool dishwasher
    Problem Solver:
  • 18 Answers
Filter is blocked
Posted on Jan 03, 2017
Testimonial: "I will check that again. I have cleaned it twice and it works once or twice then fails again. All I find is a little food residue on the grinder knife/screen. The filter is mostly clean if you mean the big white mesh that is in a round plastic housing??? Thanks for advise!"
I have a Whirpool water heater Model No. E3z5ordo55cv the T&P valve is leaking I have replaced it twice in the past week. It is still leaking. Any suggestions ???
The T&P valve or temperature and pressure relief valve is placed on a hot water heater for safety. If it is still leaking after replacement either the temperature is too high causing excessive pressure or your house pressure regulator is set to high or has failed. The water heater has a thermostat to control the temperature. Check to make sure it isnt cranked all the way up. If the water heater is old there could be a lot of sediment build up. if sediment builds up near the temp sensor it will have to superheat the water above normal levels to heat the sediment up enough to shut off. Drain your water heater and flush out all the junk then try it again.
Dec 30, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
Whirpool dishwasher overflowing water
If during the wash cycle your dishwasher overflows it could be
because the float is sticking. It is on the front right and has a switch so
that when it floats high enough the water stops.
on Sep 20, 2010 | Washing Machines
Whirpool quiet partner 3 gold. panel lights work and say it is wasing but doesn't start
The timing circuit may be defective and the circuit board needs replacing. Have an authorized serviceman do a continuity test on the board and have it rest to factory specs.
Feb 27, 2014 | Dishwashers
Whirpool Dishwasher ADP5966 Turned dishwasher on. Only light that comes on is normal wash light. Start button is flashing when normal wash light is on. On pressing start button dishwasher does not work
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
Feb 15, 2011 | Whirlpool Dishwashers
I have a Whirpool D/W Mod. GU2275XTVYO. The clean light flashes 7 timed, pauses and flashes 7 times again... Is that in the board? It will cancel and drain but won't do anything after that. Please...
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Jan 25, 2011 | Whirlpool Gold GU2275XTV Builtin...
What is the reset code for a whirpool plus quiet partner III
heated dry and high temp wash and toggle back and forth these 2 keys within 8 seconds till all the lights light up.
Aug 30, 2010 | Dishwashers
you have either a bad heater and or your water temp is too cold
toggle heated dry and high temp wash withing 8 seconds until all the lights light up
then hit cancel you should be able to use it now
Aug 24, 2010 | Whirlpool Dishwashers
I have a Model #DU960 Pwkq1 Whirpool dishwasher leaking
It is probally leaking from the vent assembly, rinse aid or soap dispenser. You will need to remove the door panel. Do this when the dishwasher is dry. Look closely for staining where the water is running down the inside of the door. Replace the gasket. Here is a couple links that should help with this.
Jun 03, 2010 | Whirlpool Dishwashers
Whirpool dishwasher does not go into wash cycle
you will need to replace the control bd. if it is not washing. I think that it is probably just filling and not starting the washing process and this would be a bad sump/mtr. assy.
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
