Have a logic portable air conditioner lpe-10hp keeps saying ft erroror wich means full tank but there is no water in unit have tryed to drain but nothing
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Means the sensor or the control board are defective
Posted on Jan 03, 2017
bluenadas
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Posted on Jun 15, 2007
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
SOURCE: ALL LIGHTS BLINK BUT UNIT IS DRAINED
Hi all,
I think the problem is that the A/C has tripped the electrical switch located in the plug. To correct press the black button followed by the clear button. Then try turning the unit on -it has worked for me so no reason it should not work for you.
Regards,
Tommie C.
Posted on Sep 02, 2008
  • 334 Answers
SOURCE: I have a portable air conditioner and the water
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
Posted on Jun 11, 2009
SOURCE: Water tank full light keeps
dod u get any help with your problem because i am having the same problem and ofcource the company is no longer around
Posted on Aug 31, 2010
The full tank light on the front comes on even after being drained.
is it a float switch stuck? Usually the pan has a switch or sensor to tell the unit when it's full. Sensor may need cleaning/drying or, as I say, may be a stuck switch.
Aug 07, 2012 | Danby DPAC7099 Air Conditioner
I am getting a code P1, what does it mean?
P1 Indicates that the water collection tank is full and needs to be drained. Turn the unit OFF & unplug it before attempting to drain it.
Hope this helped and thanks for choosing FixYa.
Sep 13, 2011 | Danby DPAC5070 Portable Air Conditioner
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
My unit keeps pouring water out what does that mean it also keeps saying full how do I make it stop or how do I empty it?
In case you have misplaced your owners manual, I have included a link to one that is almost identical to yours. There are several ways to drain the water collection tank. So, I want you to be able to choose the one that fits your situation the best.
You can download and print the manual for future reference.
http://cache.air-conditioner-home.com/manuals/soleus-ph3-12r-03.pdf
Hope this helps you.
Jul 08, 2011 | Soleus KY-34 Portable Air Conditioner
We have a soleusair portable heat pump air conditioner PH5(S) series. The tank full light is on and won't go off. We have drained the unit and still the light stays on. We are trying to use as a...
Remove the water tank and look or feel up to where the float is at and see if it is stuck in the raised position. This is what is keeping the light on and not letting the compressor start.
Jun 20, 2011 | Soleus Ph5-13r-35d Portable Air...
What does it mean when it doesn't work & it says "fe"?
FE may actually be "FT" which means full tank. Refer to http://web1.dlservice.org/dlservice/dataload/istruzio/GB-5751015400.pdf page 14.
Empty the internal safety tank, through the drain hoses. Refer to Page 16 on how to do that.
May 25, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Red light on??
that means the internal tank is full and needs to be emptied. Drain useing a bucket or the hose that came with the system. Open up drain caps and just drain it. Top and bottom caps.
Jul 16, 2009 | Danby DPAC120061 Portable Air Conditioner
Blinking ft what do i do?
According to the manual, blinking Ft and some people think it is blinking FE, Means the internal tank is full. Empty through the drain hoses. Open the cover on the rear of the AC (it is located near the bottom of the unit) Pull out the two drain hoses, remove the caps and let the water flow out. Put caps back on and place hoses back inside.
Jul 06, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Sep 08, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
134 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
