What sort of abnormal problems incur in the white matter
ERROR CODEE7-10
E7-10 Shading trouble (Black correction)
The CCD black scan level is abnormal when shading. Improper connection of the CCD unit flat cable CCD unit abnormality MCU PWB abnormality. http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Sharp&model=AR5320
upon on extra research I've found that this problem was once solved by tightening any loose panels and screws...
Thread Sharp ar5320 error code e7
Sep 23, 2015 | Sharp AR-5320 Black and White Copier
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am jeevanjyoti mahapatra from cuttack,orissa.i have never applied for any postpaid sim.but now my prepaid number is suspended for outstanding bill not paid in postpaid sim.what shall i do?
Well, there must be a mistake on their record which made them suspend your number for outstanding bill. This happens very frequently. I also have the similar problem, but mine is with different users, and I get at least 1 call from other company asking to speak one fellow, I've called and complaint the customer care several times, but they can't still find who was using the my same number before i got it, but I still hope that i'll get rid of this one day.
In the same you can also call up the customer care and tell them the situation and the problem they have incurred to you. They should take action at the earliest or else you can file a FIR with the police. I am afraid, why we indians are facing this problem, at least they should take very good care, so that they would never make any mistakes. If they do, they should apologize. Anyway, I wish you good luck.
Thanks for using FixYa.
Jun 19, 2010 | Cell Phones
Indicate h 4
When this copier power abnormal or heater abnormal then show H4
Solve: # interrupt C interrupt press 14 press start key if it is power abnormal then solve if you not solve you must be change Heater Lamp.
Mar 31, 2010 | Sharp AR-5320 Black and White Copier
I have a line running through my pictures. it doesn't matter what picture i print, i get the line
Well, there's bad news and then there's worse. Hope for the laser lens. Hope it's not the drum. By the book:
Abnormal
areas (white,
black, or
color) appear
in a regular
pattern.
The laser lens is dirty. Clean the laser lens.
A toner cartridge may
be defective.
Remove the toner cartridges with the
color causing the abnormal image.
Replace it with a new toner cartridge.
The drum cartridge is
defective.
Remove the drum cartridge and check
for damage. If it is damaged, replace it.
Mar 30, 2010 | Konica Minolta Magicolor 2530 DL Laser...
My blackjack 2 blinks yellow when i plug in the charger. it wont charge. theres nothing wrong with the phone that i can tell and when i checked the white dot it was red but it never got wet. its working...
when that white dot is red it means moisture of some sort got to the battery and mean the battery the damaged the light means the battery is charging abnormally so the best thing is ti get a new battery try ebay they are cheap hope this was helpful:)
Oct 19, 2009 | Samsung BlackJack II Smartphone
''Advanced Vista Optimizer 2009 has stopped working''
just get rid of that programe in your computer, surely it will not optimize because it incures problemes for your windows.
obviously it does not pass the windows specifications.
Sep 22, 2009 | Computers & Internet
Display some time white some time abnormal
use a nokia restoration code. follow as prompt *#7370# /yes/your security code or default code and wait.
Feb 02, 2009 | Nokia N70 Cellular Phone
White background in real world turns purple or magenta in digital photo
If you go to www.canon.co.uk. Go to technical support, then follow the links to your camera, a notice should pop up about the problem you are having. They are offering free repair for: Abnormal colours Distorted image Abnormal image It says its a CCD problem https://self-service.canon-europe.com/uk/pages/
May 02, 2007 | Canon PowerShot A85 Digital Camera
jasbo
jasbo
