Question about Proscan Televison & Video
I have a Proscan Model PLED5529A-C, can it be connected to bluetooth? I purchased a surround sound speaker that can only be used with bluetooth.
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
SOURCE: buzzing in speakers of cinema surround
I have the same problem, tried routing my speaker wires away from power wires and that doesn't seem to work
Posted on Jan 03, 2008
drumbanger
  • 1199 Answers
SOURCE: speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Posted on Dec 28, 2008
  • 4 Answers
SOURCE: proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Posted on Jan 28, 2009
SOURCE: Connecting SRS-BTM30 bluetooth speakers to my vista laptop
This has also been sending me around the bend. I resolved it by disabling the speakers on my laptop. To do this go into control panel, then hardware and sound, then change system sound. Select your speakers and disable them. This allowed me to play music through the speakers. You can also re-enable the laptop speakers after this.
Posted on Mar 28, 2009
I have purchased 2 of these speakers. I want to Bluetooth connect them to my iphone. How do I do this and get music from both speakers?? Thx
If you have purchased Speakers with Bluetooth Connectivity capability you can do this by switching on the speakers and on your iphone use the Bluetooth Pairing Option from Bluetooth settings to establish connectivity and play music to hear from speakers
Jun 15, 2015 | Audio Players & Recorders
I tried to program a universal remote to my Led Proscan tv and now it just flashes different colors. How do I get it to stop?
hi,
I think some how you have gone into service mode on the tv.
you may need to take it into a repair shop so the can re-set it back.
sounds like it to me.
hope this helps
May 21, 2014 | Proscan PLED5529A 55" LED TV 1920x1080,...
I've recently ordered a Proscan PLED5529A 55" 1080p 120Hz LED HDTV, However, a Proscan PLED5529A-B 55" 1080p 120Hz LED HDTV was sent. What is the difference? One difference i've noticed in the...
Same issue here. I'm debating to send it back as most specs are pointing to the A-B model as being 60Hz. I can't really tell of it's pushing 120 or 60 (ignoring the fact that the screen says 60Hz.) It almost "feels" like it's 120 but can't say for sure. Can anyone please confirm that the "A-B" version is indeed 120 or not? Thanks!
Mar 02, 2013 | Proscan Televison & Video
Can i hook pioneer speakers from a system to my lg flat screen
Absolutely! To provide a better solution to your problem, however, you will need to provide model numbers of your TV and surround sound system. Depending on the available hookups and your hardware, you may need a received to make everything compatible.
Feb 13, 2013 | Proscan 32LA30Q Television
Connect an active soundbar to a receiver
What if the soundbar is Bluetooth? Will I still be able to use that function and connect the active soundbar to the tv (Bluetooth) and connect the av receiver for other surround sound speakers? (they are pre-wired in the walls in the apartment I moved into)
Jan 08, 2013 | Audio Players & Recorders
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
NO OWNERS MANUAL
Go to there website to download the pdf version of the manual.
If that does not help look on the back and you should see optical out, audio out type connectors.
Most effective way would be to buy a surround sound amp and connect it via an optical out to the surround sound amp and the surround sound amp will have the connectors for the surround sound speakers.
May 18, 2009 | Proscan 42LA45H 42 in. LCD TV
Get no response from audio out to surround sound sytem my e-mail is jerryhusbands@yahoo.com
You need to give a lot more detail about you set-up. What type of surround sound Brand name and model number are you using. What type of connections are you using with the coaxial sound output to the surround sound system.Have you tested this coaxial output on another speaker source to make sure that it is not putting out sound. You can do this with a coaxial to rca adapter and use one of the receivers normal sound inputs to see if you are getting any sound from the output of the television.You also must make sure you are using the remote controls of the two components correctly. Check to make sure the volume is adjusted to a hearing level on both remotes.Check all the cables you are using and make sure they are working correctly. If after doing the testing you find that the television is not putting out sound. You will need to contact PROSCAN for customer support help.You can use their website at www.oncorpus.com. Go to the customer support section and ask for help with your problem. You can also call them at 1-888-977-6722. I hope this has helped you with your problem.
Apr 24, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan tv surround sound hook up
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
