Question about Yamaha Music
I have a yamaha psr 1100 show on display assertion failed
    New Friend:
  • 62 Answers
This is one of the most disturbing errors, the only easiest option is to replace the main motherboard, if you have a technician, check dry joints on the big ICs.
Posted on Feb 03, 2017
  • 5603 Answers
SOURCE: Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Posted on Sep 22, 2009
  • 5603 Answers
SOURCE: My Yamaha psr 275 keyboard has no sound and the
I assume by "checking the connection" that you ALSO checked that the adapter is generating the CORRECT voltage? If not, that is the first thing to check. They fail often...
Assuming the adapter is working, I would suspect that the input power connector has broken or the solder is bad or the board may have a crack in that area. In which case, removing the cover to check will be required. Care must be taken with cables when doing so.
Power problems are some of the easiest to find.
Posted on Feb 01, 2010
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
SOURCE: yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Posted on Aug 07, 2010
  • 88 Answers
SOURCE: my yamaha psr-s900
Show it to some technician in Yamaha Service Centres.
Posted on Nov 27, 2010
Yamaha PSR S550B While ON power Disply showing lines
Sounds like the LCD display is shot. Time to replace.
Jun 22, 2017 | Yamaha Music
My yamaha psr 1100 display on screen assertion
check dry joints on the main dm board or replace main processing board.
Jan 02, 2017 | Yamaha Music
Manual for PSR 270 KEYBOARD
Yamaha has the manual for the PSR-270 keyboard on the product site: http://usa.yamaha.com/products/musical-instruments/keyboards/digitalkeyboards/portable_keyboards/psr270/ . Click on the support tab. The direct link to the manual (in English) shows in my history as: http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=35052 .
I hope this helps.
Jun 03, 2016 | Music
I am using psr 1100.from last week its not workina.maasege showing assertion failed.pls give a solution
Normally this indicates a problem on the main motherboard.
Always the first thing is a factory reset.
While turning on the keyboard, hold down the right most white key on the keyboard and continue holding it down until the keyboard has finished the start up.
Or
Jul 12, 2014 | Music
I require a user manual for a Yamaha PSR 6000 Organ to down load
Yamaha has the user's guides available as PDFs for most of their instruments on their site: http://download.yamaha.com/top/?site=usa.yamaha.com&language=en . Enter PSR-6000 or select Pianos & Keyboards > Portable Keyboards > PSR-6000 and then press Select.
The link to the manual will display below the search area.
I hope this helps.
Jul 28, 2011 | Yamaha Music
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
Yamaha psr s900 screen/display gone bad
Jul 22, 2010 | Yamaha Full-Size Keyboard
Feb 12, 2010 | Yamaha Full-Size Keyboard
Sep 18, 2009 | Yamaha Music
Music Logo
159 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
