Question about Garmin nuvi 750 GPS Receiver
M7 GPS no longer has a voice. Do NOT have it on mute either.
The SErial Number of my GPS is 17D576828. I've had it for about two to three months. I did run it without using the satellite. Would this have any bearing on the voice?
    Brigadier General:
  • 4,090 Answers
No... Contact Garmin in your location your unit is under warranty and should not be intefered with
Posted on Jul 22, 2009
Does this unit have voice descriptions
You don't mention the model number, but I don't know of a GPS that doesn't have voice directions. Check to see if your unit can mute the voice or maybe the volume is down.
Jun 17, 2015 | GPS
Tomtom one won't go past voice person. It keeps starting over.
You have installed a NavTones GPS voice that is encrypted to a different device code (serial number).
  1. connect TomTom to PC
  2. navigate to 'voices' folder
  3. Delete any recently installed voices
  4. Disconnect and restart
Aug 04, 2011 | Tomtom ONE GPS Receiver
Nuvi stopped talking. where is the mute button located on the unit?
If you are no longer getting the voice guidance from your gps, then you need to check if the volume is on the highest or lowest. There is no mute button on the gps, it is when the volume is at the lowest it seems muted. Ensure the volume is turned up by adjusting the scroll whell that is by the right hand side of the unit.
If that does not help, then you check the language settings in the unit. Verify that the voice is enabled, by following these steps:
  1. from the 'where to? view map' screen, touch 'tools',
  2. Touch 'language',
  3. Next to 'voice language' you will see 'jill' listed in the blue box on the right (if so the unit should be ready to use)
  4. If you do not see a 'voice' listed in the blue box, touch on the blue box,
  5. Select 'voice',
  6. Touch 'ok' at the bottom,
That should do the work for you.
Dec 23, 2010 | Garmin nuvi 205W GPS Receiver
The voice/sound no longer works.
There are 2 things to look at
On main screen press the Vloume icon........ is there a checkmark in Mute? if so uncheck
If no checkmark on bottom of that screen press FM Trans.... uncheck Enable FM Transmitter.....
Oct 23, 2010 | Garmin Nuvi 660 GPS Receiver
Speaker works for playing of MP3 songs but does not give direction instructions when on purely satnav. Have tried increasing/decreasing volume but no sound comes out of the unit. Have also done a factory...
spoken directions are only available when the computer generated voice has been activated. If you choose any other voice, you will no longer get spoken directions
Oct 05, 2010 | Tomtom GO 730T Car GPS Receiver
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
I no longer have a voice telling me where to turn. I do not have it on mute.
first check the language settings and see if it is showing the language you wont. some times it shows no voice is loaded. If the voice is there then do a reset by holding the on off button over to left for 10 seconds. If that does not cure it then do a full rest. Be careful because this will delete any information you have stored on your GPS. Best of luck
Jul 08, 2009 | Garmin nuvi 750 GPS Receiver
No voice prompts on my new nuvi 750- volume level not muted.
I had the same problem after I had my Nuvi 750 for a few months.  The voice just stopped.  I called Garmin and they replaced it under warranty.
Feb 11, 2009 | Garmin nuvi 750 GPS Receiver
No more voice commands
Is it still under warranty
if so take it back to the store
Feb 05, 2009 | Garmin nuvi 200W GPS Receiver
No volume will not give voice prompt
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard1.gif has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck,
- Jim
Jan 20, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 750 GPS Receiver Logo
87 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
