Question about Garden
I have an old atlas model 15-5241 24" snowblower with a 5hp briggs&and statton where is the gear box located & how much oil does it hold ?
  • 91 Answers
SOURCE: 5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Posted on Mar 30, 2009
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
merth3
  • 13 Answers
SOURCE: Got a point type 5hp briggs model 130292. I want
Something is causing the spark timing to be late. Check it with an old neon timing light after marking top-dead-center with paint. .
Posted on Sep 18, 2009
SOURCE: wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
Posted on Dec 30, 2009
daneinwv
  • 124 Answers
SOURCE: how do you set the gap between the coil and the
My name is Dane and I am going to help you solve your problem.
Too set the gap for the coil get a regular buisness card and use it as a feeler gauge. Loosen the bolts to the coil. Rotate the flywheel so the magnets are next to the coil. Slide the buisness card in between the coil and the flywheel magnets and make sure the coil is tight against the card.
Now tighten down your coil bolts and remove the busisness card. Turn the flywheel at least 1 complete turn and make sure it doesn't hit the coil. You're done!!!
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 05, 2010
How much oil does a briggs & stratton 5HP engine need
Manuals You can download the manual for your particular engine from here.
Oct 22, 2016 | Briggs & Stratton Measuring Tools &...
Model # 627804x79a. Spirit snowthrower. How much oil does it take?
what does the manual tell you about engine oil
Nov 24, 2015 | Garden
Briggs instructions
Locate the drain plug on the bottom or side of the engine (might have a drain pipe attached to it) remove plug let oil completely drain screw off filter and replace (if equipped) refer to manual or Google and find out how much oil the engine holds (maybe around a quart) replace oil check for leaks and go mow your grass
Aug 15, 2014 | Briggs & Stratton Garden
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
I have a 5hp 24"
Check to be sure there is oil in the gear box! Wish I could be more help for you...
Jan 11, 2011 | Craftsman Garden
Briggs engine identity problem on craftsman tiller
sears.com
enter your mod#143.707012
May 26, 2009 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
