How do i set my tk30 so radio sound stops when receiving a call
Sync my iPhone 5 music to the Motorola tk30 - there is no volume on the Motorola?!
First make sure the software is up to date. Motorola Support Find Answers Motorola Mobility Inc .
Then check the manual on page 22 about music play on iPhone.
How are you using it? Via Bluetooth?
Also make sure your phone volume is up and your stereo. If you just had it installed. Contact the professional installer to ensure it was installed properly.
Motorola Support
Feb 20, 2015 | Motorola Mobility Genuine Tk30 Music &...
Why can't I get sound on radio setting or any other setting?
Hi, just to start off the speakers are in and the volume is up, right. What do you have plugged in, for example a DVD player? The mode is set correctly for the item plugged in right. For the radio, an antenna must be plugged in to have it come in correctly. Hope this helps.
Jun 02, 2014 | Yamaha HTR-6130 Receiver
Static stops when i stop moving
The radio may have been installed incorrectly or the squelch setting is incorrect or the antenna connection is not properly grounded
Nov 09, 2013 | Midland 1001Z 40-Channels Base CB Radio
Motorola t7 - 1 unit has receive indicator permanently on (except when you PTT when icon switches to send) and will not engage other unit. How do I reset to manufacturer settings as removing battery does...
Hold in the PTT and the monitor button while turning on the radio (wait for the sounds to stop) will put you into programming mode. You can then use the menu button and the +/- buttons to walk you through the settings. Using this menu, you can program your radio to match your other unit.
To read out your master radio, put it in programming mode, and simply press the menu button to walk through the settings. Do not press the +/- along the way, as it would change a setting. Once your have your master radio read-out, you can proceed with programming the one you are having a problem with.
Best regards.
Jul 27, 2011 | Motorola T7100 2-Way Radio
How to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Feb 29, 2008 | Audio Players & Recorders
Sound quit
Check the fuses inside?
Aug 23, 2007 | Motorola DCP-501 Receiver
Sony Receiver has little sound on radio stations
have you adjusted your sound settings while in listening to the radio mode?
Jul 30, 2007 | Sony STR-DE875 Receiver
XM reciever FM transmitter problem
hi the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the can call xm to ask for that OR do it online at and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
46 people viewed this question
