Question about Epson Office Equipment & Supplies
I'm having an issue with multiple epson tm-c3400 printersusing one ink cartridge per day. Normally we go through one per month on average. Any Ideas?
SOURCE: EPSON TM T88IV
The TM-T88IV printer is a thermal printer and does not have ink or a ribbon.
If the printer is not printing you may have the wrong type of paper in the printer. You must have thermal paper in order for the printer to work. Paper for a dot matrix printer will not work in this printer.
The printer has a self-test that you can perform by turning the printer off, holding down the Feed button and turning the printer on. A test strip will print. Press the Feed button again to print a longer test strip.
Posted on May 16, 2008
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Epson DX8400 does not recognise ink cartridge
on the ink cartridges there should be a little gold chip on them if they dont have that then your printer will not recognise the ink my best bet for you is to buy cheep and reliable placement epson ink or you can buy these ink cartriges which have tubes which feed ink into these replacement cartridges and i have got one of these my self and i would recomend these to anyone
Posted on Apr 15, 2009
  • 11 Answers
SOURCE: Epson CX8400 ink cartridges run out early
Epson gives you a miserable 12 ml of ink. Then it reports empty when there is still 10-15% of the ink left. I saw someone set up a brand new CX8400, print a single 4x6 photo and it said he was out of cyan. I use reusable cartridges from http://www.ccs-digital.com They hold 20 ml, which is 2/3 more ink. The chips automatically reset to full if you take the cartridge out and put it back in, so you get to use every drop. The ink is in a separate container inside the main cartridge. When it's really empty, you pop out the ink tank and pop in a new one. The tanks are under $3 each. I think this is brilliant because it's like refilling only it avoids the risks and mess of refills.
Posted on Jul 07, 2009
SOURCE: I have replaced the Epson ink cartridges for
I Have this problem too with the pink ink, ive replaced it and now it will not detect that there is even an ink cartridge in the printer at all...
Posted on Mar 20, 2010
Epson t60 two orange lights blinking
use this interactive guide to resolve the issue. They are considered red lites not orange. FYI
Epson Printer Error Lights INTERACTIVE Meaning of Red Blinking Leds
Dec 10, 2014 | Epson TM-T60 Printer
Just purchased an Epson Stylus Pro 10000 Archival Ink. Nosel check looks good with solid lines, however prints are very light. Ran clean multiple times. Printer came with existing ink and I don't know if...
Old ink loses some of its intensity after about 8 months.
heat/light seems to destroy some of the depth in the ink's shade. i would be completely replacing the cartridges with fresh ones. Constant cleaning uses up so much ink and the casettes will need replacing too often. This raises the cost of your prints.
May 09, 2010 | Epson Stylus Pro 10000CF InkJet Printer
Two Cartridges of 4 Not Recognized (new, empty-chipped)
No matter what you do, it will not recognize it.
Brother and Epson's require original epson ink.
Good Luck.....
Nov 19, 2009 | Epson Stylus C84 InkJet Printer
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
Epson printer
HOw do I clear a paper jam on my epsom dx 4450 printer
Apr 02, 2009 | Epson Office Equipment & Supplies
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
