Question about Emerson Fans CF770BC Monterey Ceiling
I have a ceiling fan with lights taht go on and off
I have a ciling fan with lights. it has 5 bulbs 3 of which will only stay lite a few minutes after I loose and tighten and wiggle tham. Thanks
    Problem Solver:
  • 15 Answers
I had a similar problem - the center terminal where the light bulb screw in became somewhat corroded. If you turn off the power, you can clean these with a small piece of fine sandpaper - then bend them slightly outward so that when the bulb is screwed in, they make good contact. If that doesn't work, and you have a voltmeter - check the voltage at each bulb socket to make sure the internal wiring is ok. Not to overstate the obvious - but make sure the bulbs are ok too....
Posted on Jul 21, 2009
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Broan bath fan light
probably you cross the wire, read the manual, check the wire first.
connect all the white wires together, connect the black wire from the hot source to the one side of the switch and connect another side to the light, this is for the light. and do the same for the fan.
the factory use either red or the black for hot,white for the neutral and green for the ground.
I hope this can help you.
Frank
Jul 02, 2008 | Broan-NuTone Designer 721 Ceiling Fan
Lites overheat
soley:
are you talking about the lite bulb base? what kind of lite bulb in use?
pc-cook
Jan 22, 2008 | Dryers
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Emerson Fans CF770BC Monterey Ceiling Logo
117 people viewed this question
Top Emerson Fans Dryers Experts
Dan Webster
Dan Webster
Are you an Emerson Fans Dryer Expert? Answer questions, earn points and help others
