Question about Vacuums
My Dyson 04 will not turn on after hoovering up sand by my Nephew
    Problem Solver:
  • 7 Answers
The filters in your unit are abole to stop sand particels getting to the motor chancse are the motor is now dead but this is not a repair you shound under tack as dyson are realy nasty to tack apart and put back to gever due to a lot of platic clips in hard to reach places and if they brak the unit is no god
Posted on Jul 23, 2009
Dyson ball dc25 filter B keeps popping out
Hoover or dyson , can not be both
Jul 22, 2016 | Dyson DC25 Vacuum
How do I assemble this hoover
Hi Peter, it's Jack at Dyson.
DC40 Multi Floor should be quick and easy to assemble - no tools are needed, the parts will just clip together. Our Getting Started video guide shows you everything you need to know:
I hope this helps. If you need any further advice, just give our experts a call. You can reach the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 01, 2016 | Dyson DC40 Multi Floor Upright Vacuum
Dyson brush not turning?
The brush wont move it is quite often that your belt has snapped you can get them from any good hoover outlet or order on li
Jul 23, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Just stops working during hoovering
Hi, it sounds that you may have a fault in your cable sometimes the wire inside the cable gets broken and only connects now and again when in the right position. I remember reading some where about this person had a dyson and had to get the wire changed for a second time as this was the fault. They put it into a dyson repairer to get the job done as you have to remove the motor. I no that's what you need to do on a dc07 animal. If its not the cable then it could be the temp cut out switch my first motor would go for so long hoovering then just stop and you would have to wait till it had cooled down then it would go for another short time. I had to get a new motor that time but it was covered by dyson . When the dyson man arrived i told him it was cutting out and he just fitted a new motor. I have since just replaced that motor myself rather than buy a new dyson. Always remember to remove the plug from the socket when doing repairs to your hoover.
Feb 20, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
On my dyson dc24 the hose will click in but when I start hoovering again the hose unclicks and comes back out
TRY CLEANING AROUND THE RIM WITH A TOOTH BRUSH ,AND DRY ,A LITTLE LIGHT SANDING PAPPER A ROUND THE RIM MIGHT MAKE IT FIT BETTER
Apr 09, 2013 | Vacuums
Just stopped mid hoovering and now won't switch on!
It is probably a thermal cut-off which is caused by a blockage. The machine will turn itself off before it overheats if it is a thermal cut-off. Once it has cooled down, you will be able to turn it back on again (usually 30 mins - 1 hour).
If the machine doesn't turn on at all anymore, you may need to replace the power switch. Call the Dyson helpline, they will do a blockage troubleshoot and if it's not that, they will tell you where you can find an authorized Dyson repair dealer in your area.
Jul 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson Absolute 04 hoover, the brushes underneath do not turn,I can see the belt but am not able to get into to it to change it.could you please assist. thank you.
HELLO, YOU HAVE 4 SCREWS THAT YOU TAKE OFF THE BOTTOM COVER TO REMOVE OR HELP GET TO THE BELT, IF THE BELT IS'NT BROKE TRY SPINNING THE BRUSHES BY HAND TO SEE IF YOUR CAN SPIN IT OR BREK IT LOOSE IF IT IS THE BELT THEN YAA REMOVE THE BOTTOM COVER TO HELP REPLACE THE BELT.
Mar 29, 2009 | Vacuums
Hose buckling/crumpling when hoover is turned on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=34170&thid=580414
Hose buckling/crumpling when Hoover is turned on
Posted by mildwarthog on May 08, 2008
Hi - I'm having a problem when I turn my Dyson DC07 on, that the suction is causing the hose to buckle/crumple out of shape which then means I can’t Hoover through the hose. After a short while the motor starts to overheat from trying to maintain suction through the crumpled hose is it simply time to buy a new hose, or is there anything else I can do to fix this problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Dyson DC07 All Floors Bagless Upright
Once you hose starts to breakdown there is really nothing you can do other than replacing the hose. This is true on almost every vacuum on the market because they are using in most case the plastic hose and the heat and the product you pickup breaks down the hose and starts to lose its strength and starts to collapse. You may want to check with your local vac dealer to see if he has a new one or a good used one for ½ the price. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.dyson.com/homepage.asp
Contact Us
1-866-MY-DYSON
(1-866-693-9766)
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
questions@dyson.com
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 08, 2008 | Dyson DC07 All Floors Bagless Upright...
My vacuum doesn't **** at all...
Hi umanski... release the hoover as though you were to use it normally... please turn the hoover upside down.. it should be lying flat to the floor now.... being careful that you dont have your fingers or anything else in the way... switch the hoover on.... is the brush roller spinning?
If not it is your brush belt has gone and needs replacing, which is fairly straightforward. Expect to pay approx £4-7 for genuine dyson belts (2).. though you can get generic copies for about £2.
Does this solve your prob, if not let me know.
regards Faggly
Mar 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 suction when upright but no suction when tilted in operate position
Not sure if this will definitely fix the problem.......but here goes for anyone with the same problem....spoke to Dyson helpdesk today following some online research i did yesterday. The 'internet' view is that there is a design fault with the cyclone chamber of the DC07 and that older models need it replaced. Mine is a 2003 model and Dyson asked me if there was a Number 1 stamped on the back of the cyclone housing near where the air duct connects to the hoover body....there wasn't. They then said they would send out a new cyclone chamber free of charge (I bought my model as reconditioned in 2007 from an approved Dyson dealer, so no Dyson warranty) suggesting they are aware of a problem. Advice on another site by someone who was also sent a new cyclone is that the holes in the early cyclones were too small and got easily clogged. I'm now waiting for my new part and will see if that fixes it.
very strange though - my old DC01 was a far better model from what I have seen so far of the DC07 - they seem to have gone backwards in design & reliability.
Very impressed with the service from their helpdesk though - they put other companies to shame with their speed of answering the phone and the ability to actually talk to someone not just a series of automated menus - well done Dyson for that at least - I'll reserve judgement on the DC07!!!.
Dec 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
93 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
