Does it come with an audio digital cable - Audio Players & Recorders
  • kakima Jan 02, 2017
    Hi Jim Walsh, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is "it"?
    Master:
  • 502 Answers
If you can't find one I'd say that is a no.
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
I have a kenwood VR405. I am useing a samsung blu ray and a cox cable box. both components are running directly into the samsung flat screen via HDMI. I am backfeeding digital audio to the VR405 via...
Josh, define the 'backfeeding' of the digital audio from the two HD components into Video 1. Those are ANALOG inputs on the VR405. You have two coaxial- and one optical-digital audio input you could/should be using.
I'm surprised you're getting ANY audio (much less digital audio) from the BD and Cable Boxes unless you also have an analog audio path coming in from (what?) the TV.
http://img.inkfrog.com/click_nelarge1.orig.php?image=100_2147.JPG&username=gceparts&aid=773763271
Sep 29, 2011 | Kenwood VR-405 Receiver
I just purchased a Coby TV Model number TFTV 3255. I am very happy with the set. However it has only ONE audio output. The manual, on page 7, "coaxial output" ,an optical audio cable is required....
If it is a single output and looks like an RCA type, then I would say that the cable you would need is a digital coaxial cable. The optical input/output will have a different shape and is not as big of an opening as a digital coaxial input/output.
Mar 01, 2011 | Televison & Video
No sound coming from speakers from the xbox 360
you have to connect the digital audio cable from your xbox360 to your receiver. fiber optic cable. set the xbox audio output to dolby digital.
Apr 26, 2009 | Onkyo HTR500 Receiver
Question: how do you connect to a cable box?
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Jan 31, 2009 | Coby DVD-937 5.1 Channel DVD...
Optical audio from cable box to receiver
Do you mean the optical digital audio output from the cable box? This is so you can listen to Digital sound from cable tv broadcast, First go to the cable box remote control, select setup or menu to find audio, then select audio output, check digital audio, not mts or stereo, this should enable to optical output instead of the typical 2 channel red and white left and right RCA analog audio outputs, sometimes different cable boxes vary, but most require you to enable the optical output via the method listed above.
Jan 28, 2009 | Yamaha HTR-6140 Receiver
Can only get the dvd player to use the surrond system
This is going to be a bit tricky with this model, since either your Cable or Sat box will need a Digital Audio Out, and you will need to purchase a Digital Audio cable. If your sat box has a digital audio out, connect a digital audio cable from the sat box to the digital audio in on the back of the Samsung. Then connect a red and white AV composite cable from an available audio out on the back of the cable box to the "Aux In 2" on the back of the Samsung - this may only allow stereo sound, however.
Your absolute best bet (and the simplest connection) will depend on whether your TV has a SPDIF OUT or Digital Audio Out (they are roughly the same). If your TV has a Digital Audio out, connect a digital audio cable from the TV to the Digital Audio IN of the Samsung. Now you will get sound from any cable, sat, or any other type of box that is connected to your TV.
-Tha Mp3 Doctor
Dec 25, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Digital audio out in XW4300
Right, it uses a fiber optic cable that connects to the "Digital Out" on your computer. There is "harmonic distortion" with the use of the RCA cables; the louder the output volume the greater the distortion. When using the "Digital Audio Cable" the is only pure data signal, aka DSP (Digital Signal Processing), because the two devices communicate with Infrared light flashes through the fiber optic cable; trust me you can hear the difference. You may need to buy one of those cables if your receiver did not come with one.
Nov 30, 2008 | Computers & Internet
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Does not decode Dolby Digital 5.1 from my cable box
If you have an HDMI cable plugged into the cable box it may only output 2.0 on the digital audio output. Set the HDMI audio to off or 2.0 and then set the cable digital out to Dolby.
Sep 01, 2007 | B&K AVR-507 Receiver
 Grubhead
Grubhead
