CAN NOT GET TV THROUGH HEAD PHONES ANY MORE ALL RADIOS COME THROUGH BUT TV AS STOP COMEING THROUGH WHY EVERY THING CONNECTED AS ALL WAYS WAS
2 Suggested Answers
  • 157 Answers
SOURCE: the head phones doesn't stop loud speakers sound
most likely the switch at the back of the headphone plug is not working properly, this requires the laptop to be dismantled and have the jack repaired/replaced. Very expensive at most places. was it working previously?
Posted on Jun 16, 2009
On my tv the pc hdmi under the setup has a circle with a line through it . I need to connect my tv with hp stream notebook. I have not been using this tv so the setting and cable are not connected
what are you trying to do..? end goal.
my guess is HPside , is missing the correct HDMI divers
one can say play netfix on PC and push it up to TV
one can use pC as a sources of files, a file server
and the TV sees them and can play those media files
2 ways, off top of head.
this does not compute (cant work like that)
I have not been using this tv, so the setting and cable are not connected.
Feb 09, 2017 | HP Computers & Internet
E2000 van oil comeing out of cyls.3 and 4 very black and sticky.just fitted overhauld head.what could cause this .
there is a head gasket problem probably from the head bolts not holding the head down tight. When working on a head always make sure that tye head stud holes ore clean by using a thread tap and blowing the holes out with compressed air. Oil, water and gunk will stop the head stud from screwing all the way in yet you will still achieve the tension setting because the stud has bottomed out--hence the head gasket is not under correct pressure and the head studs are not under the correct tension.
Jan 11, 2015 | Cars & Trucks
How do I stop my binatone mr 250 transmitting when earplugs are connected?
The jack is probably for the ear phones and the microphone, you will need compatible accessories for that radio.
May 26, 2014 | Radio Communications
Why can I not get sound when I hook up my DVD
not enough info, need to know what ports your connected to on tv, are you on the right channel, some tv s will ask you where the video/audio source is comeing from.
Mar 06, 2011 | Insignia 42" Flat-Panel Plasma HDTV
How do you get at yor cabin filter on a 2001 ford taruse car. if it is pluged will that stop the heat from comeing full blast i have heat but not as hot as it should be.in the coolent pot there is little...
hi from uk the problem your symptoms describe esecially the bubbles that are appearing in the coolant header tank would suggest that the poor heat in car is due to air locking in the heater and this is most probaby the air bubbles you see in head tank are also finding their way into heater matrix via heater hoses may i suggest that asap you visit garage for a cooling system pressure test because theseair bubbles should not be appearing and is a sgn that you may have a cylinder head gasket in early stage of failure and what these bubbles are is compression in cylinder/s is leaking via gasket into the coolant system and emmiting in the head tank however i do say early sign so a compression test on cooling system will confirm whether or not ? considering cars age? it is not uncommon especially if high milage or any history in past of overheating ? hope this helps
Dec 23, 2009 | 2001 Ford Taurus
Not transmitting or receiving when plugged in
The head set is stuck in Transmit. try shutting off the radio and then plug in the headset then turn on the radio. some radios can since the presence of accessories but the accessories must be connected before powering on the radio.
Jul 21, 2008 | Midland AVPH1 Motorcycle Headsets 2-Way...
TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Mar 06, 2008 | Televison & Video
Motorola spectra
Those should be for the speaker.
Jan 19, 2008 | Radio Communications
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
