Question about Sanyo Televison & Video
Sanyo 50843. No power or green light. I replaced the power board. Still no power or green light
  • Sanyo Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.....
No power or green light Sanyo 50843. I replaced power board. No change
The main board turns on the power supply. Replace the main board.
Jan 02, 2017 | Sanyo Televison & Video
I have a Sanyo dp42740 plasma TV , the green light on front comes on for about 2 seconds and goes off. what is it?
Hi Gray,
Please try giving 13V from external source. When we exhaust all the options of changing boards we try such things to get the set working. I hope it helps.
Good luck
Aug 04, 2015 | Sanyo Televison & Video
Why does the Sanyo tv have a flashing green light and not turn on?
This is because the blown power board will get power to light the LED but not enough to operate the picture and sound. Check that the caps on this board are blown, and replace with exact parts. The fix can be $10.
Jun 16, 2014 | Sanyo Televison & Video
I realized my Sanyo tv post may have been confusing.
There always is the possibility that the replacement power board is defective.
Aug 26, 2017 | Sanyo DP42849 42 in. HDTV
Sanyo DP46819 green ind. light comes on but no screen or audio
Not true that its def the power. Mine did the same thing. Green light, no sound or video. Replaced the power board with same results. Waiting on main board now.
Jun 07, 2012 | Sanyo DP46848 LCD TV
I have a sanyo vizon 50" tv that wont turn on. the green light comes on and the relays click but nothing happens and eventually the light goes off. any advice? thanks
Power supply board have problems,not giving the tv,the right voltage anymore,that why the LED power light indication go off.The power supply board,that the board,where the power a/c plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Oct 13, 2010 | Sanyo Televison & Video
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Hello my Sanyo dp42849 42 inch has no picture and no sound. when i turn on the tv a green light in the bottom right hand corner comes on and occasionally flashes off and then back on.
First, you need to know the sub-model of your TV.
It is called "chassis" and is shown on the back of the TV on the label where the model number is shown.
For example it can be "P42849-00" or "P42849-01".
Then search at or just go to and enter the link for SANYO DP SERIES to search for that.
Here's an example of a repair service (note it may NOT be the one for your exact model though!):
Hope this helps!
Jul 16, 2010 | Sanyo 42 in. LCD TV
Sanyo DP50747 Replaced Power Supply still not working
I have same problem. Walmart is selling Sanyo junk You are not alone lots of web chatter about these lasting 2 years or less, Mine lased 19 months, Trash it & buy a different brand. I originally was going to buy a Samsung & now I will.
Sep 22, 2009 | Sanyo DP50747 50 in. Plasma TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
