What can I do when my windows 7 will not let me in. No error message. Just won't do anything when I select the account.
Can't reset windows 7 logon password as error
try this :
  1. Download the Reset Windows Password utility onto an alternative computer. Unzip the download file, you'll get the ResetWindowsPwd.iso file. Burn the ISO file to CD using an CD burning software such as ISO2Disc orBurnCDCC.
  2. Set your Windows 7 laptop to boot from the Live CD. To boot from the CD-ROM drive, you may need to press a key such as F8 or F12 while your computer is starting up and set CD/DVD as the first boot device in BIOS.
  3. After the CD boots, you will have a mini operating system loaded into memory which will launch Reset Windows Password utility. It will not install anything to your hard drive.
  4. Click on the Reset Windows Local Admin/User Password option, the program will automatically detect the Windows SAM registry hive and local user accounts existing in your local computer.
  5. Choose the administrator account and click on Reset Password button, it will remove your forgotten Windows 7 administrator password in a short time.
Feb 17, 2013 | Computers & Internet
How do I fix error 571 on my 9800 monarch ticket machine using my loftware 32 design ticket?
If you are getting error 571 from Nebraska Book Company's WinPrism inventory control system, File --> System Settings --> set the Receipt Type to 8-1/2 X 11. It seems irrelevant but it works.
Another possible resolution to the problem is to remove the Windows (XP, 7, 8, 10) profile of the offending user:
0. Login as the offending user and backup anything they want to keep, like browser bookmarks/favorite or documents on the desktop.
1. Log into Windows as a local administrator.
2. Control Panel --> User Accounts --> select the offending user --> Remove.
3. Restart.
4. Log into Windows as a local administrator.
5. Delete C:\Users\offending_user
6. The following is necessary to avoid a "temporary profile" error: Regedit.exe HKEY_LOCAL_MACHINE --> Software --> Microsoft --> Windows NT --> Current Version --> ProfileList --> select each entry until you find the one with a ProfileImagePath of C:\Users\offending_user and delete it.
7. Control Panel --> User Accounts --> add the user.
8. Login as the offending user, add the printer, and now it should work.
Jun 15, 2012 | Office Equipment & Supplies
I had to replace a bad hard drive for a Sony Vaio and first installed Ubuntu, now trying to install Windows 7 instead, but won't work...one error message says hard drive needs to be formatted with...
  1. Boot from Windows 7 CD.
  2. You'll be asked to select the language. select your preferable language
  3. Then you'll be asked to accept the license agreement.
  4. Then you'll be asked to choose the drive where windows 7 will be installed.
  5. Select any drive and click format in the advanced drive options.
  6. Your drive will be formatted in NTFS and windows 7 will be installed.!
Nov 03, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Error 5
Windows Vista or Windows 7 users may experience a Printer Error 5 when attempting to print from your MYOB software.
To overcome this issue, turn OFF the User Account Control (UAC) in Windows. See below for instructions.
Note: Our support note Printer error messages, definitions, and solutions can be used if you are not using Windows Vista or Windows 7 and are receiving a Printer Error #5.
To turn off UAC in Windows Vista
-Close out of your software.
-Click the Windows Start button and choose Control Panel.
-In Windows Vista click User Accounts and Family Safety.
-Click User Accounts. You may need to select a User Account, if so, choose any account.
-Click Turn User Account Control on or off.
-You will be prompted with a window entitled Windows needs your permission to continue. Click Continue to this message. If you are not setup as an Administrator user on this machine, you may be prompted to enter a Administrator Username and password.
-Deselect the option Use User Account Control (UAC) to help protect your computer then click OK.
-You will be prompted to restart your computer. Click Restart Now.
-You may get a warning to Check your computer security. This is a standard message that Windows recommends User Account Control to be always turned on.
To turn off UAC in Windows 7
-Click Change User Account Control settings.
-Click and drag the slider to the lowest position, in other words Never notify.
-Click OK.
-Restart your computer to complete this change.
Jun 26, 2011 | Canon MP140 PHOTO AIO All-In-One InkJet...
Error 1603
When you try to install a Microsoft Windows Installer package, you may receive the following error message:
Error 1603: A fatal error occurred during installation.
If you click OK in the message box, the installation rolls back.
To resolve this problem, do any one of the following, depending on the cause of the problem:
  1. On the Windows desktop, double-click My Computer. The My Computer window appears.
  2. Right-click the drive that you want to install the Windows Installer package to, and then click Properties.
  3. Click the Security tab.
  4. On the Security tab, do the following:
    • If you are using Microsoft Windows 2000, verify that the Name box contains the SYSTEM user account.
    • If you are using Microsoft Windows XP, verify that the Group or user names box contains the SYSTEM user account.
    If the SYSTEM user account does not appear in the box, follow these steps to add the SYSTEM account to the box:
    1. Click Add. The Select Users or Groups dialog box appears.
    2. In the Name field, click SYSTEM, and then click Add.
    3. Click OK.
  5. In the Permissions section, click to select the Full Control check box underAllow, and then click Advanced.
  6. Do the following:
    • If you are using Windows XP, in the dialog box that appears, click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box for the SYSTEM account, and then click OK.
    • If you are not using Windows XP, in the dialog box that appears, click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box for the SYSTEM account, and then click OK.
    Note If you receive a security message, click Yes.
  7. Wait for the operating system to apply the permissions that you have selected to all child folders.
  8. Run the Windows Installer package.
Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
Error code 810003c1
Error connection with Windows Live Messenger
After failing to connect to Windows Live Messenger, Below error message appears on your screen :
"The connection to Windows Live Messenger failed - The service is unavailable - Please retry later - Error Code 810003c1"
This problem is usually related to registration information for Messenger account, specifically the country of assignment.
It is probable that the connection established for an account, but may not work with another account.
How to proceed
Exit to Windows Live Messenger
Go to Windows Live Hotmail website.
Go to Identifying Windows Live ID and Password.
Click on Windows Live and select “Account”
In the page “Account Summary”, click on ("Edit your registered information").
Under Home, select your country of residence.
Then save the modification by clicking on “Register” and close Hotmail.
You can now try to connect to Windows Live Messenger.
Regards
manish
Mar 09, 2010 | Microsoft Windows Live Messanger
I am having problems installing canon iP5200 with Windows 7
Did you upgrade the computer from Windows XP to Windows 7? If so, did you uninstall the driver before you did the upgrade? The old driver files may be causing the problem.
To fix, go to this link, and in the search box in the center of the screen type "windows 7" and click on the Search button. Then select the link "ERROR: Cannot communicate with the printer after upgrading to Windows 7". There will be step-by-step directions for resolving your problem.
Dec 29, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Error code 8e5e0155
how to fix Error code 8e5e0155
Aug 23, 2009 | Microsoft Windows Live Messanger
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Error Messages.
Dear coolsoph,
I could help u more if u can tell me the error messages u r getting but no problem dear i still help u out. what u have to do is just unistall the network driver to uninstall the network driver Right click on My computer-> then select properties-> the select Hardware-> then select network adapter right click on that and then uninstall the network driver after uninstalling the network driver restart the system and then Reinstall the network driver the problem will solved.
Regards,
Bittu_8
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
