Question about Cameras
Ergorapido lithium light is blinking in small 2 in 1. It is fully charged. Not sure why it is blinking.
5 Suggested Answers
joboo1
  • 257 Answers
SOURCE: Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
Posted on Feb 05, 2009
  • 44 Answers
SOURCE: Kodak Easyshare Z760 orange light flashing
The flash does not charge separate from the rest of the camera. Try cleaning the flash sensor on the front of the camera or the flash led may be bad.
Secondly, this light functions as a flash sensor which is trying to tell you that you need to use a flash although you may have the flash manually turned off. looks like a bolt of lightning with a circle/slash through it.
Posted on Mar 15, 2010
  • 111 Answers
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Posted on Mar 16, 2010
bento_daniel
SOURCE: I have a 2 year old Electrolux ergorapido cleaner
No, not worn out batteries.
For my experience, if the batteries were worn, they would charge with the blue led being on and after that, the vacuum wouldn't hold his charge. just that.
This is a different problem. Check the contacts between the charging station and the vacuum, mines got bent a bit and stopped making contact. This has happened twice and just fixed it about 30 min ago. That is why the led first lights and then goes off, there was just a brief contact between them.
Nice vacuum, very powerful and handy but maybe it is just poorly made as it is engineered in Sweden but built in China.
Posted on Sep 12, 2012
Hello, Nikon Coolpix 8100 camera. Battery has difficulties loading. light blinking at back stops aft. several minutes, then beep, and start blinking faster. Blank screen confirming battery is empty.
The behavior you describe is a camera connected to a computer and it changes WHILE the computer sees the camera and it is ON (computer). When you shut down the Computer it will blink rapidly and it will not charge. if you charge with POWER ADAPTER. It will only BLINK while it charges. When it STOPS blinking it is FULLY charged.
Apr 25, 2018 | Nikon Cameras
I bought a Ryobi 12V drill w/ lithium charger. Green light on charger never went solid....continues to blink & fade. Does this mean its in the energy saving mode? Is it fully charged?
How long have you left battery on charger? It will take about 3 1/2 hrs to fully charge. t is probably not a good idea to leave the battery in the charger for long periods of time though, so once it is fully charged put it back in the drill. When fully charged the green led will turn solid. This link will have more info on charger and battery.
http://powertool.manualsonline.com/manuals/mfg/ryobi/130155001.html?p=2 C
Apr 19, 2017 | Ryobi Drills
Nikon lithium ion battery not charging
Make sure you ha e the charger plugged in the wall, thats a common mistake then put battery in port make sure it clicks in tight the light will start to blink the its charging. When it stops blinking it is charged
Apr 29, 2014 | Nikon D3000 Digital Camera
Electrolux ergorapido plus
Christmas 2013 I was given an Electrolux ergorapido. I put it on the charger and red light won't come on or if it by chance does it flashes three times and then cuts off.
Aug 13, 2013 | Vacuums
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
I have a digipower lithium power charger TC-U100 and cannot get my Casio NP-60 battery to charge in it. Am I inserting it wrong?
Maybe. This unit charges all different kinds of batteries, but that requires you to make sure that you have set the prongs in the right position to connect with the particular battery you are charging. You move two pins to align with the outer contacts on your battery (not the middle one) and then a spring door holds the battery against them. The unit sets the polarity automatically. 4 lights blink green until the battery is fully charged at 4 solid lights, i.e. 1 blinking light is a quarter charged.
Nov 22, 2010 | Mizco Digipower Lithium Ion Digital Camera...
Batteries are charged, flash doesn't go off and camera shuts down, ready light blinks amber, then read and then shuts down
Since the flash requires lots of energy it sounds like you have a battery problem. 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 24, 2010 | Kodak EasyShare C340 Digital Camera
Low battery light comes on with fresh, brand new batteries. After several uses it seems to drain the battery and when I turn it on the red ring blinks and it turns off as if there is no charge.
Here are the steps:
There is no firmware available for this model online.
Dec 16, 2009 | Kodak EasyShare Z7590 Digital Camera
Cameras Logo
51 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
