Question about Building Materials
My garage door won't open. It goes up to 12 in. Then stop an will make a grinding noise. With assistance it will go up the rest of the way. What could the problem be?
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
SOURCE: garage door will not open or close
I had the same problem, mine was just the white Sprocket assembly, it stands straight up, there is another one which is the Worm gear, mine was fine. I read on some other post, when you take off the panel, and if you see a lot of white dust (shredded white plastic) then its the gear. Went to Sears warehouse, had the part in stock and replaced it myself. Had to just unbolt the Sprocket assembly from inside (3 bolts), pull out from the top, a little hassel, but got it done. Follow the instructions and you will be fine. Remember after greasing up the sprocket like it says too, take the time to use some silcone spray on the springs and rollers, a lot of people forget to do this, even me...
Posted on Jan 03, 2009
  • 244 Answers
SOURCE: Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Posted on Jan 15, 2009
  • 118 Answers
SOURCE: garage door won't open
You probably have a broken spring on your door
Posted on Jan 18, 2009
  • 3197 Answers
SOURCE: craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Posted on May 03, 2009
Garage door stalls
The mechanical bearings and gears need some lubricants to smoothen the rotation. Try to apply some on the roller paths and joints
Aug 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Loud, grinding noise from garage door opener
Remove the cover from the motor housing and check the drive gear.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a maytag msd2656kes. A noise has developed in the ice maker that stops whenever you open the freezer door. There is a momentary switch that I push on the left inside wall of the freezer that...
Looking at your wiring diagram, the icemaker is wired through the light switch. So when you open the door it stops power to the icemaker and the noise stops,push the light switch and it starts back up again.
A lot of times the motor, or module will go bad in the icemaker causing somewhat of a grinding noise like it is trying to do something but cant. 99% of the time it is best to change the whole icemaker to avoid further issues but sometimes you can just change the module depending on the condition of the rest of the icemaker.
Feb 08, 2018 | True GDM-12 Refrigerator Commercial
Can't reattach the door to the trolley and grinding noise, won't move
Pull straight down on the rope and release. Then you should be able to run the opener and the two halves of the trolley will click together. Sometimes you need move the door by hand to get this done. The grinding noise is most likely the drive gear stripping. Remove the cover from the motor unit and it should be obvious.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2HP garage door opener making noise but not opening
TIME TO REPLACE THE GEAR KIT PARTS ARE AVAILABLE IF YOU ARE A REASONABLE MECHANIC IT IS A DOABLE REPAIR - FOLLOW THE INSTRUCTIONS!!!!!
Apr 09, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman garage door does not open all the way stops @12 inches
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift master garage door opener. Motor makes noise when switch is hit likes its running but chain/sprocket doesn't move and the door is stuck open. Chain is on sprocket. Not sure if the motor is frozen? ...
I had the same problem. Took the cover off of the opener and found that the gears were stripped on the unit. Motor was fine. You can order gear replacement kit for the unit. They are a plastic type sprocket and worm gears. The kit comes with spindles and all necessary clips. You have to take the unit off the ceiling to replace the gears, but the process if very easy to do. Parts kit about $40 on line, much cheaper than a new door opener. Total process took less than 2 hours, including getting the unit down and back up again.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't open
Nov 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
37 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
