Question about LG Washing Machines
How do I get the sound back on my lg washer model WT568OHVA?
  • LG Master
  • 2,309 Answers
Press and hold the 4xtra rinse button for 3 seconds. Cycles thru low to hi to off.
Posted on Jan 05, 2017
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
I have LG washer model#WM2140CW leaking water underneath when I turn the washer on
take top off(two screws on back, then slide top back about 3 inches and left up and off), start wash and take a look inside, you can see most of the hoses from there.
Sep 13, 2015 | LG WM2140CW Washer
How do I find model number and serial number on LG washer and dryer?
front load washer upper part inside door frame
top load upper right side back
your looking for a metal plate.. it will have the serial number and the model number.
Sep 18, 2010 | LG Washing Machines
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
Electronic display was flashing LE. Unable to open front load visible water. Tried to restart...unable. What is your best solution to open front and get washer working again? washer is...
Waht make? Model?
Sounds like an LG
You might want to unplug the unit for 10 min -then plug it back in and then power up , then press pause.
LE- could be a motor sensor, main board issue - wiring issue
Affordable Appliance repair
Orange County, CA.
Aug 22, 2009 | Washing Machines
LG front load washer wont drain and makes loud buzzing sound. Have cleaned drain cartridge. Is there another drain cleanout?
Sounds like the impeller has come off the pump motor shaft. If you push it back on, it will just fall off again. You will need to replace the pump motor. Let me know the model number you have if you'd like detailed instructions on how to replace it. (instructions are a bit lenghty, and I'd rate the repair about a 6.5 or 7 on a 1 - 10 difficulty scale.)
Mar 24, 2009 | LG Washing Machines
Noisy on spin cycle LG WM1832CW
this is joyce
Go to and download your manuel put in your model #
Feb 07, 2009 | LG WM-1832C Front Load Washer
Need repair man for the LG WM0642H washer. I live in northern NJ. Washer sounds like a helicopter at 18 months.
right here on to the service directory and shop around for your area,,,your spin surport basket most likely leak through the back tub seal..
Jan 06, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
