Question about Acer Extensa 4220-2148 Notebook
Speakers are not working and also when i hook up the mike and headphones is telling me it is working but no sound comes out
What do I have to do to hookup a headphone to my 60 in vizio TV?
Without opening set, easiest thing you can do is hook up a small receiver to the audio outputs of tv and then plug your headphones into the headphone output of receiver. And when not using the headphones you can always hook up some external speakers to the receiver - they will always sound better that the speakers that come with the tv.
Feb 23, 2017 | Vizio Televison & Video
Front audio and mike ports not working
There are two things you can do. First the easy one. Turn your laptop on then on the right side of the touchpad there is a + - and the off for the builtin speakers. touch that make sure it is red then plug your headphones in. That should do it but if not. go to start then click control panel go to hardware and sound and you can change it there make sure you have the headphones plugged in when you go there so that your computer can see them you will see a picture of headphones click on them.
Mar 14, 2013 | HP Pavilion Computers & Internet
My sound card isn't working and I have installed drivers now with speakers hooked up it tells me they are unplugged
Test sound via headphones to isolate problem. The green input is for speakers. Some cards will also allow you to change input / output, but this is dependent on their software.
Aug 20, 2012 | Compaq Creative Sound Blaster PCI 64 Sound...
Problem with sound
Headphone socket is pushed in too far, need to hook the end of the socket inward to contact the speakers when headphone is not used.
May 02, 2012 | Computers & Internet
Speakers getting power but not sound
check the speaker.. could be burned or open connection
May 17, 2010 | Logitech Z523 2 Speakers
No sound comes out of the tv speakers, it used to be hooked up to suround sound but not anymore.
Hi
Can you hear sound from headphone socket if so cheek speakers and clean or replace headphone socket
regards windyhouse
Mar 24, 2010 | Televison & Video
2005 dodge caravan, factory dvd... no sound through speakers
My grandcarvan sxt came with a remote for the DVD system and wireless headphones from KOSS. You have to press the headphone button on the remote to change it to headphones otherwise it comes through the main system. With the button pressed we can listen to cd or radio in front while they wear the headphones in back. You might need the remote to change it back to main system. The headphones from Koss are lifetime guaranty and not too expensive.
Dec 06, 2009 | 2005 Dodge Grand Caravan
Dell studio xps no sound will come out of the speakers
I assume you mean the internal speakers.
First thing I would try is hooking up a set of headphones. If you can hear sounds thru the headphones then there could be an issue with the headphone jack. (the jack acts like a switch, switching OFF the speakers when you have a plug inside, and switching them back ON when you remove the plug).
If you dont hear sounds thru the headset or speakers, check your device manager, and remove/reinstall your audio driver. You can download the driver at the dell website Support.Dell.com.
Oct 26, 2009 | Dell A525 Computer Speakers
Can't get sound through speakers/headphones
You need to connect the speaker wire coming from the monitor to your PS3 if you want the sound to come out of the monitor speaker. Normally, you need an adapter for this.
Mar 15, 2009 | Computers & Internet
Headphones are not working
As soon as you connect your headphones to your laptop,some options wil come regarding the mike system,in that you choose the headphone option to get sound only in headphones OR By clicking on the speaker icon and selecting the Mixer button, you should be able to turn off the other outputs.
Aug 23, 2008 | Computers & Internet
Acer Extensa 4220-2148 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
