Question about Golf
My electric go cart is not working . Says battery is charged...no loghts no noise or anything? ?
2 Suggested Answers
  • 330 Answers
SOURCE: electric golf cart won't go forward nor backwards.
check key switch, and fuses.set brake before putting it in gear.The relay diods that controll power may have a wire off.
Posted on Apr 21, 2010
Why won't my electric club golf cart run? It makes a noise when I put it in drive or reverse & it won't move. I added some water & charged it & it seemed like it was doing fine until it shortly died.
Ok, first I hope u are putting distilled water in the battery, not just any water. Should not overfill it either. Looks like the electrolite ( sulfuric acid) in your golf cart had been diluted to the point where it doesn’t hold a charge. Also when u wipe all that stuff around the battery please wear gloves and safety goggles. Looks like u might need a new battery for your cart. Good luck!
Jan 23, 2018 | Golf
Electric golf cart won't run on cold mornings. I hear solenoid click but nothing happens. When the temp warms up, it runs normal. I replaced controller, solenoid, speed control and ITS & switch.
Depends on how cold it's getting outside. Cold weather is ******* a battery. Try load testing your batteries. That "clicking" noise makes me believe that it's trying to start, but it's not pulling enough amps. Considering everything that you've already replaced, I would start there. Assuming you've already made certain all of your connections are good. Also, make sure the ground wire for your electrical system is good. Not loose, corroded, etc...
You can even call the local golf course and ask to speak to the golf cart mechanic. I would get several calls a week from drivers when I worked as a diesel mechanic.
Oct 20, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
Jan 24, 2016 | Golf
I bought a 2010 zone electric cart and I do not think the battery charger is working. It will show fully charged and will not last but about 20 minutes please any advise
First of all take your battery to a place that sells batteries and have it checked. Sounds like your battery is only partially charging but the charger will show fully charged as it won't charge any more. Battery could be bad.
Dec 26, 2014 | Golf
I bought a 2010 zone electric cart and it will not run but about 20 minutes on a full charge can anyone help Please
Check the battery for voltage. May be shot and won't fully charge even though it says it is.
Dec 26, 2014 | Golf
Free wireing diagram on a 1987 DS Electric golf cart
I have 1987 club car golf cart. I need the battery wire diagram.
Jan 01, 2009 | Electronics - Others
Golf Logo
564 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
