I need someone to come to my home and tell me if this can be fixed or if I need to get a new disc player that will be compatible with what I have, I need a technician to look at it.
  • kakima Jan 02, 2017
    Hi Patricia Markle, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
2 Suggested Answers
  • 15 Answers
Try re-recording the dvd to the other dvd format. ie if it's on a DVD-R record it to a DVD+R also here is the number to Funai, they make Emerson, they may know more 1-800-256-2487. Hope this helps.
Posted on Feb 01, 2008
Why won't home made DVD's work
some dvd &cd players won't play home made ones.iwas told you can change the format when you burn them. don't know how or if that will work.
Sep 05, 2014 | Televison & Video
Ive only had my blu ray player for a little less than a year and tried to play a dvd the other day and got a "no read" code. How do you fix that?
check first the region compatibility of you player and the DVD disk next clean the lens of your player open the cover of the player,using a cotton buds gently wipe the lens of the sure the unit is unplug before operation...tnx.
Aug 20, 2010 | Panasonic SC-BT200 Home Theater Systems....
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
DVD plays OK on computer but not on Sony DVD player
It must not be compatible with you player.
Refer to your manual.
Oct 12, 2009 | Sony Televison & Video
LITEON LVW 5024G make the disc compatable with other DVD players
This is how I do it:
Push the Guider button and go to finalize disc.
Jan 27, 2009 | Lite On LVW-5005 DVD Recorder
Need installation instructions for phillips divx ultra
Please tell me the exact problem what you having????
With DVD player Or With TV???
If at all you are getting "no disc" on your player its due to Disc compatible mean to say that Not supporting.
If at all there will be a Player Lens Problem.
Jan 08, 2009 | Philips DivX Ultra HTS6500/37 Theater...
Toshiba D-VR610KU recorded disc won't play in my Daewoo DVD5800
What are the compatible types of DVD's that the Daewoo DVD5800 player is supposed to play? Is DVD-R among the compatible types? Try playing the new recordings on a computer that has a DVD drive, or a friend's computer.
Apr 20, 2017 | Televison & Video
Dvd compatibility
use nero 7 8 to make your movies best easyest
Jan 22, 2008 | Microsoft Windows XP Home Edition
DVD Player
Sep 24, 2007 | Emerson EWD2202 DVD Player/VCR
When should I use a DVD-R / DVD-RAM / DVD-RW?
Write Once – After finalizing, a DVD-R disc can be played back in approx. 95% of home DVD players and PC DVD drives Capacity – 30-60 minutes (depending on the selected filming mode) of high quality motion video can be stored on a single of a disc. Re-writeable – DVD-RAM allows for recording and re-recording of movies and still photos up to 100,000 times per disc. DVD-RAM is like a removable hard drive. Compatibility for video playback of DVD-RAM in standard home DVD players is fairly low. DVD-RW cannot store true .jpeg digital still photo’s like DVD-RAM, however it is re-writable and has 80% compatibility with home DVD players.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
