The chime on the washing machine upon pushing the starting button is silent. How do I turn it back on?
  • 87 Answers
SOURCE: washing machine
Replace lid switch
Posted on Jun 17, 2007
SOURCE: washing machine faulty
had same problem...fisher paykel ecosmart gwl11
unplugged machine and drained as much water by tipping toward back (with my brother's help) being careful to not let water get into control panel. when weight became manageable, undid hose clamps at bottom of unit to drain rest of the water. brother (electrician) fiddled with some of the wires to the transformer(?) at bottom of machine - he said one was loose-- this seemed to fix the problem.
Posted on Mar 31, 2008
ngfam1
  • 639 Answers
SOURCE: washing machine wont start on any cylcle,
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
eagle338
  • 4889 Answers
SOURCE: Compaq f756NR laptop won't boot.
I think this is a problem with the laptop's LCD display. To verify this connect the laptop to an external display and see if it resolves the issue. If it does then its confirmed that its a display related issue. Since the issue has appeared suddenly I dont think its a serious problem. May be just loose/disconnected connectors. Should be a 10 minute job for a qualified technician.
If the external display too doesn't come on then its an issue with the graphics card and you may need to replace it.
Posted on Oct 24, 2009
  • 159 Answers
SOURCE: hey, my f&p smart drive 9 excellence washing
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
Posted on May 29, 2010
How do I get the chimes to work on a howard miller grandfather clock they worked fine till I rewound the weights and stopped
There are a number of things that can cause this. The most obvious is to ensure the weights have been wound up (either by pulling the chain or using the key that comes with the clock). Next is to ensure the clock isn't on "silent" mode. Some clocks, especially the more expensive models, have a small pull rod just behind the clock face. You can usually find it by opening the front door, and looking just under the wood frame the surrounds the clock face. Pull or push to enable/disable silent mode. The next option is to look at the clock face/dial itself, check to ensure it's not on silent. Sometimes there is a lever on the right or left of the clock face. Next, some "triple chime" clocks have either a turn dial or lever on the left or right of the clock face. This lever usually has four options Westminster, St. Michael's, whittington and silent. Check to ensure it's not on silent. If it's on for example Westminister, try moving it to St. Michaels. If the clock then starts to chime, you know there is an issue with the movement that needs repaired. You can also open the clock, if you feel comfortable and check the lifting levers aren't stuck, I've found this a few times. Additionally, while it's a bit hard to explain, on some movements there is a long rod that pulls almost all of the rods back at the same to make the "bonging" sound when the hour chime arrives. This sometimes ends up misplaced on the wrong side of the chime hammers. As you can see there are a number of things that can cause a clock to stop chiming, but a little research on your model and some confidence and you can usually fix most problems fairly easily. The only exception is if the movement has been neglected over the years (failure to oil etc), in which case a rebuild may be required.?
Dec 02, 2017 | Home
I touched a button & now we cannot receive calls. What did I do?
Perhaps you entered "Silent Mode"...
"Silent Mode" is entered by pressing and holding the [ # ] key
on the handset for a few seconds (model D1680 & similar).
The easy way to end "Silent Mode" is to go to the BASE and
press the [ANS ON/OFF] button to turn off the answering
machine system. (push the button, do not unplug the power)
"Silent Mode" will clear a moment later and you can again
turn on the answering machine system as desired.
Mar 26, 2015 | Uniden Lands Phones
How do I turn off silent mode
Feb 27, 2015 | Uniden DECT 6.0 Cordless Telephone...
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Aquarius wf620 super silent washer has "test" in
  • to de- activate press and hold the start/cancel button untill all the lights come on.
  • then press and hold the on/off and start/cancel buttons together until d-off appears
that should do it and if not get back to me, there is another way you can do it.
Jul 11, 2011 | Hotpoint Aquarius WF220 Front Load Washer
My LG Washer isn't working. The little chime that rings whenever it is turned on happens but then NOTHING else. No lights, no codes, nothing. I spin the dial but there's nothing, no noise and no lights....
the machine has suffered a power failure?push and hold the main power button plus another button together hold both buttons in for about 60 secounds the machine should reset.adrian.
Mar 16, 2011 | LG Washing Machines
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine will not start wash - just beeps - key on display
Press and hold the Rinse Plus button and wait for the washer to start emitting a tone.
Whilst you are pressing and holding the Rinse Plus button, the tone increases in volume from low to high and then it briefly goes silent, before it starts over agian.
If you release the Rinse Plus button immediately the tone goes silent, then this will turn off the beeping.
If you don't release the Rinse Plus button in time, just continue to press and hold the button and the tone will cycle around again from low to high to silent.
Hope that helps.
Dec 07, 2008 | Audiovox Bosch 718 World Cellular Phone
Washing Machines Logo
Top Washing Machines Experts
