Question about Insignia Televison & Video
Insignia pdp42x40523 plasma tv
Hi ive changed the power supply and clicks on then off also unplugged my y and x boards to narrow down same thing clicks on then off with no sound or pic then with everything hooked back up there are three connections on lower left of power supply that comes from main board with the top two unplugged it doesn't click on and off do I have a bad main board? thank you very much
  • 44 Answers
SOURCE: Bad power supply and regulator circuit
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 304 Answers
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
Posted on Jul 17, 2009
  • 30 Answers
SOURCE: power supply is bad on philips plasma 50 inch tv, it just clicks
nice job... thats the most common problem with all LCD tv's now
Posted on Jul 21, 2009
  • 70 Answers
SOURCE: insignia ns-pdp50 plasma. pop of death, audio but no video
I suspect that your supply has gone bad. You will need to find the service manual for voltage measurements. If you want to get replacement boards many can be found on ebay or you can check they stock boards for many units and I have had no problems.
Posted on May 04, 2010
  • 33 Answers
SOURCE: I have a Hitachi P50H401 plasma TV ,when you hit
unplug the unit for a while like one hour or so.
Posted on Sep 03, 2010
Can someone help me fix a Panasonic TC-P42S30 plasma TV?
Could be an open internal fuse or power supply failure
Sep 06, 2017 | Panasonic Televison & Video
I have a Sanyo dp42740 plasma TV , the green light on front comes on for about 2 seconds and goes off. what is it?
Hi Gray,
Please try giving 13V from external source. When we exhaust all the options of changing boards we try such things to get the set working. I hope it helps.
Good luck
Aug 04, 2015 | Sanyo Televison & Video
Insignia 42 plama stopped working
There are so many resons for a plasma TV to shut down
. It might be due to a faulty main power supply section. Main digital section fault. Y-Sustain fault. These are the common faults to plasma shut down. You have to locate the exact faulty board. There is normally no repair to these boards. Card base replacement should be done.
Get into this site, and read articles related to plasma tV repair. there are so many faults and rectification proceedings described in detail. Read them and make sure that you can do this work by yourself; and proceed. Type in 'electronics help online.blogspot' to your browsers search box, click open the site named Electro-help for details.
Jun 28, 2012 | Insignia 42" Flat-Panel Plasma HDTV
I'm having problems turning it on. It just clicks and the LED light is blinking.
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Oct 15, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Insignia ns-pdp50 plasma. pop of death, audio but no video
May 04, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
The tv not stay on.You can here a relay clicking on and off.But will not staw on.
Check these things
!.power supply
2.inverter both master and slave
First start and the power supply then the inverter, if under warrenty take it back, if not and your still in doubt call the manufacture for the best repair option, Thanks
Jun 26, 2009 | LG 42PC3DC 42 in. Plasma HDTV
2004 sony wega 37'' plasma tv not turning on.
You most likely have a power supply problem. but the problem may not be the actual power supply. The drive cicuits for the plasma panel can load down the power supply and give you the symptoms that you are having. Without being able to be there and take voltage measurements, I'm afraid I can't narrow it down more than that. My first suspect is that one or more of the sustain boards (the boards that drive the plasma panel) have failed. That would explain the lack of display. It is likely one of 3 boards that has failed, PSU (power supply) logic (the main control board for the set) or DE2 (panel drive board). There is a chance that the panel itself is bad, but that is not the most likely cause of your problem
Nov 18, 2008 | Sony WEGA KE-37XS910 37 in. HD-Ready...
Televison & Video Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
