Question about Coffee Makers & Espresso Machines
What is the procedure for descaling a Chef's Choice 685 International Deluxe Cordless Electric Teakettle kettle, using vinegar and water? Can't find my manual.
SOURCE: How to descale Philips HD 4651/C Electric Water Kettle
Not having received any solution message from FIXYA contributors, I consulted with a family member
and also my long held Time-Life Books, Fix It Yourself Library, Volume: Cleaning & Stain Removal,
ISBN: 0-8094-7400-X, Copyright 1990. My issue was resolved by using white vinegar and soaking the internal problem area for 30 minutes. The appliance has cleaned up like new and works fantastic. I apologize for bothering you.
Posted on Nov 28, 2008
  • 22 Answers
SOURCE: kettle gets heavy white residue on inside after a couple uses. we do not ever let it stand with water inside.
Cheapest fix is to use white vinegar to disolve the building up of limestone hardness in your water. I am certain that you find it difficult to get soap to lather well, you have a bathtub ring every time you take a bath, your towels and sheets are stiff and scratchy and your lower legs itch terribly especially in the winter. You have very hard water and you need a water softener. Find a Certified Water Specialist in your Yellow Pages.
Posted on May 25, 2009
SOURCE: where can i get a replacement lid for the chef
used a metal nut to replace the plastic one,
Posted on Jun 17, 2009
  • 9 Answers
SOURCE: MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
Posted on May 23, 2010
  • 153 Answers
SOURCE: Talea giro plus / Descaling with vinegar
There are a couple of things I am thinking for this:
If the espresso machine is not spraying the hot steam like it should it says in the manual to take apart the steam apparatus and clean with hot water then to run hot water through the device after each use to clean.
Furthermore, have you seen those CLR commercials? I am sure white vinegar would be fine to put through the machine. As far as the ratio is concerned use a low concentrate to start out like 1 to 3 then increase until desired results occur.
I hope this helps!
Posted on Nov 06, 2012
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
How do i clean my glass kettle from lime scale
try vinegar neat white or brown its less corrosive than the branded descalers which do work quicker i admit but my kettle started to leak
because of these strong cleaners now i use vinegar its cheap.
place 500 ml to 1 litre in kettle switch on just warm vinegar and switch off leave in for 30 minutes swilling round empty and you can keep in a bottle and repeat every month if you wish or use in cleaning solution if you don't want to waste it look on internet 1,000 ways to use vinegar.
wash kettle with copious amounts of water inside and then use kettle cleaned and sparkling
Aug 06, 2014 | Kitchen Appliances - Others
What info do you need?
This answer may be too late but first clean this thoroughly with vinegar. Try now to see if anything changed but do a very thorough clean.
Nov 08, 2013 | Chef's Choice Electric Cordless French...
Leaking jug
A common cause is the calcium, or some other minerals in the water eventually ate through the bottom of the tank. You will need a new tank, or better... A new kettle.
Jerry G.
May 07, 2012 | Russell Hobbs RHOK3123 Cordless Electric...
How do you clean the inside of your metal kettles
if you wish to remove limescale, then you can use limescale remover either liquid or powder.
follow directions on the product of choice.
alterativly use vinager, just pour undiluted vinegar into the kettle and let it rest for a while until it no longer produces bubbles. then rince well.
if there is still limescale then repeat the process.
Note
do not let the kettle boil with vinegar or limescale remover in it. they may cause a fault and some
very bad smells.
I hope this was useful..
May 23, 2011 | Morphy Richards 43691 Cordless Electric...
How do you clean a Breville JK73 kettle. I have lost the instructios.
Put a cup of vinegar and a cup of water into the kettle and boil. Clean with a brush, rinse, boil once with clean water.
Aug 05, 2010 | Breville JK73 Cordless Electric Kettle
Kettle gets heavy white residue on inside after a couple uses. we do not ever let it stand with water inside.
May 24, 2009 | Aroma PV435502 Electric Kettle
Nov 27, 2008 | Philips HD4651 Electric Kettle
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
