Question about Dryers
I have an old hot tray with a broken male plug. Can I get this part?
  • Dryers Master
  • 5,323 Answers
YOU CAN REPLACE THE WHOLE PLUG BE TAKING IT APART AND REPLACING CORD
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
I purchased a Salton H-350 warming tray and looking for lead to plug unto U. K. plug
I need to purchase electric code for Salton Hot Tray plug, the model is H-350. The one I was using is damaged please help me.
Apr 04, 2011 | Salton Elec Food Warmer Warming Hot Tray +...
It looks like the plug on the blower melted slightly now the blower doesn't work can it be repaired
Parts are few for these machines (all I found was the blower tube). That being said, you can carefully cut off and remove the faulty male plug and replace it with a repair piece like you would add onto a damaged extension cord (outdoor type). They are made of plastic, but are fairly sturdy. Just carefully cut away the old male connector (the shrod isn't really necessary and remove the wiring from it. After purchasing the male-type plug replacement, rewire it and you will be set to go. To eliminate the male cord and the female end of the extension cord you will use from pulling apart when in operation, just loop the female end cord around the cord of the blower and it will hold in place.
Mar 19, 2011 | Toro 51585 Power Sweep 7 Amp 2speed...
I have a Schumacher WM-10000A speedcharger and the ground pin on the male plug (built into the unit) has broken off. I need a replacement male plug for this unit. It has been a great charger and I cannot...
Too easy...go to any of the DIY stores, Lowes or the Depot, or your local hardware and pick up a male end for the cord. It's an easy installation, will take you MAYBE 10 minutes.
Jan 27, 2011 | Schumacher & Fast Charge Starter Charger
There is a green wire with a 2 prong female end in the center back of the cook top. where does this attach I have looked and felt everywhere. I spoke to tech support he said it was the grease pan ground....
Angeashmore: We had the same green wire problem. The catch is that the 2-prong female plug just looks like it should receive a matching 2-prong male plug. In fact, at the center back of the pull out Drip Tray there is a very small flange next to a small hole. That flange slips right into the plug, but under those two prongs which then hold it in place. Its length allows you to disconnect when you remove the Tray for cleaning, but if that's the first time you spot it loose, you'll think it plugs in somewhere up front and will look in vain for a matching 2-prong male plug. I'm guessing they provided a ground for the Drip Tray since it is otherwise fully suspended on nylon rollers. No instructions about this in the set-up manual, so likely omitted frequently. It's just a ground wire, and won't really fix anything else, and would appear to work just fine without it, but just a safety feaqture. Confirmed by tech support at Viking on 1/24/2011. Your initial post put me on the path to success here, so thanks! .....Jim
Nov 29, 2010 | Viking 48" 6 Burner, Griddle Professional...
Coleman 564 refrigerated cooler - Need male plug. Where to find.
get a new plug from lowes. it will tell you what collor goes were. cut old plug off and take with you.
Jul 03, 2010 | Coleman (100076) Compact Refrigerator
Do you have a wiring diagram for a 50 amp male plug using 6-3 wire?
The configuration of the plug may vary by design but the way it is wired is the same no matter the plug configuration. Using 6/3 wire with no neutral white wire you simply connect the the Green ground to the ground on the male plug and the black and red wires to the other two plugs. Does not matter which. The is a 3 prong male plug. If you are using 6/3 with ground then connect the ground to the green ground plug, the white the direct opposite side as the ground and the red & black to the X & Y plugs, either one. This is a 4 prong male plug. If you are using a NEMA locking plug the lug that is bent is the ground. Connect the green ground wire there and the two other wires to the other lugs. Does not matter which one as each is carrying 120 volts. Look at the photo below. The plug on the left is a typical 3 prong plug. Notice the ground is connected to the top U shaped ground connection. The remaining 2 hots are connected to the two other lugs. On the right you see a 4 prong plug. You have the extra lug for the neutral. 9e28e8d.png
Jan 06, 2010 | Lincoln Welding Tools
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Dryers Logo
27 people viewed this question
Top Dryers Experts
