Question about Garden
I have a bolens trator with snow throwerand the auger is rotating backwards
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
  • 144 Answers
SOURCE: Yard Machine 5.2 HP snow
Hi, The only thing I can think of is that your sheer pins are broken. Can you turn the auger by hand? If you can, look at the shaft that the auger is welded to, If you can look for bolts or holes on the auger center shaft, You will have to punch out anything that is left there. If that's the problem measure the diameter and length of the old bolts, or go to a shop that sells parts to get new sheer pins. You can also use ordinary bolts that will work well. Have you checked your belt to see if it is broken or has come off the pulley or if the belt tensionner is still on the belt or has come off not providing the right amount of tension so the belt does not slip in the pulleys and is able to turn the auger. Regards and good luck. I hope that is the problem and can be fixed easily and is cheap to do.
Posted on Jan 14, 2011
  • 4088 Answers
SOURCE: We have just installed the
This appears to be a Sears model number--go to: www.searspartsdirect.com and enter the model number minus the decimal point. This will bring up a series of drawings of all of the replaceable parts for the machine. Locate the pulley that you speak of and see if a 'key' is shown to lock the pulley to the shaft. Hope this helps!
Posted on Feb 01, 2011
  • 144 Answers
SOURCE: The auger on my snow
Hi, I will try to help you with a few suggestions that could be the problem. I have found that sometimes the shear pins break, but the ends of the pin do not fall out. Have you tried to remove them by hammering them off? Another possibility, if that is not the problem, then the auger gearbox might have a damaged gear or maybe just a broken or loose bolt or pin. If that is the problem then you need to take it apart. If that is not the problem you can check the lube level by removing the plug on the outside of the gear box and check for lubrication. Whatever type of lube that machine uses should be even with the bottom of the plug hole. If it is low or there is none at all add what is recommended in your owners manual. That is just preventive maintenance. But I think it might be just the ends of the pins not having fallen out. If that is the problem then you will need a punch to remove the center of the pin that is on the auger shaft. Hope this is helpful a bit, at least it is something to check out. Best regards and good luck.
Posted on Feb 03, 2011
  • 22 Answers
SOURCE: Both augers turn when not trying to clean snow,as soon as I try to use it and snow gets to the augers,only one auger moves on my ariens 520 snowblower
It sounds like the auger always turning is the auger engagement handle/line/connections are not adjusted correctly. They/it is too tight causing the auger to engage before it should. It may be up at the handle where you loosen a jam nut, screw in or out a threaded shaft, and retighten the jam nut. (If you have ever adjusted a bicycle brake it is similar.) (I have a craftsman, made by MTD, and I think I saw MTD also list Ariens.) Or it could be an adjustment somewhere else (but I'm not sure where).
As far as one auger moving and the other not, you may have a shear-pin (shear bolt as the manual calls them) on each side of the auger's shaft (my craftsman has one on each side), and the one on the side that stops turning is sheared off. (It moves without snow present due to the driveshaft inside the outer auger shaft turning, but it won't turn under load (snow).) You may confirm a sheared-pin by turning the machine off and try to turn the auger blade. If it turns somewhat easily, that's a bad shear pin. Remove the old shear pin. If the old one is as long as the new one, that aint the problem. The shear pin in the image is one kind. Mine appear as a straight bolt (no grooves), threaded the entire length. You will have to rotate the auger blade until it aligns with the hole in the shaft. Use a nail that fits and rotate the blade until the nail goes in. Remove the nail and screw in the shear bolt:
The auger clutch control up at the handle looks like this:
25398197-u3i4ko1tk2s0xlbbi4fvvtzj-2-2.png From my manual
Auger Control
  • To check the adjustment of the auger control, push forward the left hand clutch grip until the rubber bumper is compressed. There should be slack in the clutch cable.
  • Release the clutch grip. The cable should be straight. Make certain you can depress the auger control grip against the left handle completely.
  • If adjustment is necessary, loosen the hex jam nut and thread the cable in (for less slack) or out (for more slack). Recheck adjustment. Tighten the jam nut when correct adjustment is reached.
Here's another view of that:
I hope the above info helps you take care of both issues.
Posted on Feb 03, 2015
Snow blower runs and auger/ blade rotates but the wheels Anne not rotating. 2- stage Aries 5520. Not sure if the thrower piece is rotating. Any answers for getting wheel moving/ working
Most self propelled units have 2 belts. One for the auger, and one to power the wheels. Check the belts, and then check the drive assembly under the motor to see if it is engaging.
Dec 03, 2016 | Garden
The auger is no longer turning. How do I fix it?
Check for broken shear bolts first. Then, move on and check the auger belt. Finally, if all those are ok, check the gear housing on the auger drive shaft (right in front, between the two auger blades).
Feb 02, 2016 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
Where can I find detailed instructions on replacing an auger?
first remove the chute. then remove the bolts holding the auger in place. then rotate shaft by hand and find the two roll pins that hold auger assembly shaft. drive these pins out and you auger will slide out the front of unit
Aug 28, 2014 | Yard Machines 26" 208cc Two Stage Snow...
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
Right side of snowblower is constantly clogged with snow
Check the R.H. auger my guess is you have a shear pin that has broken and needs to be punched out and replaced. If it rotates freely (cleaned out of snow) then that's likely your problem. You can prove that by watching the shaft the auger is riding on if the shaft moves with the auger shear pins ok. If the auger moves seperate from the shaft the shear pin is at fault.
Feb 21, 2013 | Ariens Garden
The 2 rotating parts in the front that the snow is sucked into the machine, only half of it is rotating the other is not moving at all this causes the snow to pile up in front. whats missing or broke?
There is a shear pin that is broken.it looks like a bolt that is designed too break if you hit something that is hard and won,t break up.while it is not running rotate the side of the auger that is not turning untill the holes in the auger and the shaft line up then put new shear pin through auger and shaft.
Dec 27, 2010 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
