Question about Water Heaters
What does it mean when ur boiler flashes a1 what is the fault plz
2 Suggested Answers
SOURCE: fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Posted on Dec 01, 2008
How do i reset the thermal cut off switch on a vaillent boiler?
Hi, what model Valliant and are there any fault codes showing?
Feb 21, 2015 | Water Water Heaters
Worcester Boiler Greenstar 15Ri - The blue neon light is flashing - what does this mean?
http://www.worcester-bosch.co.uk/homeowner/literature/gas-boiler-literature/greenstar-15ri-literature. Hope this helps :)
Sep 19, 2014 | Water Heaters
Ideal icons boiler keeps flashing h1
ideal icos
H1 fault
flow thermistor
part number 170917
i would check the wiring is secure to the thermistor first
Sep 16, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Protherm
What is the make and model of the boiler?
Jun 03, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Sime Domestic Boiler
could it mean circulation alert!!!
Mar 22, 2009 | Water Heaters
Bosch boiler System
it means that the boiler wants to be serviced, the boiler will still work fine. Once the boiler has been servcied, there are a succession of buttons, that need to be pressed, to tell the boiler that it nhas been serviced. then 365days after it will do it again. Its there to prompt you, to get the boiler serviced
Dec 11, 2008 | Water Heaters
Fault light flashing 1 flash per second
Nov 30, 2008 | Bosch Water Heaters
Water Heaters Logo
41 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
