Question about Maytag Dishwashers
Maytag dishwasher dwu9200bae stopped draining.
5 Suggested Answers
SOURCE: maytag mdb8600awq dishwasher drains good 20 seconds and stops
Dont know if you still have this problem, what I did was this - press the start button and keep going until you reach the number '2'. Leave it at '2' and in a couple of seconds it will start draining the rest of the water. Worked for me.
Posted on Oct 28, 2008
  • 401 Answers
SOURCE: Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Posted on Feb 25, 2010
Daniel S
  • 4323 Answers
SOURCE: Maytag dishwasher MDBH985AWS1 won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Jun 19, 2011
ercupa190
  • 12223 Answers
SOURCE: Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Posted on Apr 02, 2013
I have a Maytag Dishwasher, Model # WU482, ser # 01625706XT. The Water is not being pumped out , I checked Belt, and it is oK.
water pump out drain hose to sink kinked /stopped up if new disposol was installled and the installer did not take the dis/washer plug out it can not pump water to the drain
Mar 18, 2011 | Maytag Dishwashers
My maytag dishwasher won't drain
Check the screen in the bottom of the washer for food blockage. also check drain line for blockage from washer to the drain that it connect's to.
Food will stop drain's up and cause you problems of not pumping. This would be a first to check if it just started or was getting worse.
Aug 14, 2010 | Maytag Dishwashers
Feb 25, 2010 | Dishwashers
Maytag mdb8600awq dishwasher drains good 20 seconds and stops
Feb 19, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
MAYTAG DISHWASHER MODEL MDB7100AWQ
My MDB7100AWQ has suddenly stopped working. It will fill but then stops and will not move into wash. When I press the drain/off button the lights work but it does not drain. I do hear a switch in the door operate when I press the drain/off.
Jan 21, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Maytag dishwasher
Many dishwashers now have seperate drain and wash pumps. Often the wash motor stops because something is caoght in impeller. You need to remove lower wash arm then take of cover...should be torx head screws to get to impeller.
Nov 06, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
