Question about Kitchen Appliances - Others
I cannot get the disc adapter of the slicing disc. It is stuck. How do I remove it
Xbox 360 door tray off track and will not close
First, do not attempt to try to fix it right away. Unplug every cable and adapter, so you only have the xbox 360 console. Then, if a video game disc is still in there, take it out. Next, try to determine what your disc tray is stuck on, and try to remove it carefully. If these steps do not work, look at these articles. Manually eject your Xbox 360 console disc tray Xbox Disc Drive Solution.
Oct 11, 2014 | Microsoft Xbox 360 Console
My dc adapter is not staying connected properly. Can I fix it or get a replacement? I am having trouble finding the right one, 5V 200mmA.
First, double check the voltage on your adapter; XM uses BOTH 5Volt AND 6Volt adapters, and you need the correct one.
Second, sometimes the little plastic end of the DC adapter will come off and get stuck like a horseshoe over the little center pin. You will need a needle to remove this little plastic circle. Once the broken-off plastic disc is removed, your adatper will work much much better. See if that's the case and let me know.
Sep 07, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Our toaster stopped working a little while ago, but it is outside the (presumably) one year warranty period. It's a 4 slice, soft touch black toaster, cost about £75, I think it is this model. It only...
remove from the electricity supply
remove crumb tray,
remove bottom 4 os 6 screws.
at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!!
put it back together abd try it
if it does not work 4 slice toaster from Tesco £9.99
Nov 09, 2009 | Dualit 45375 4-Slice Toaster
My disc stem is stuck and will not come out.
Without careful use and care, there is a possibility that the disc stem can become fused with the motor shaft. If excess pressure is being applied to the slicing or shredding disc, this can cause immense friction and cause the plastic disc stem to "weld" onto the motor base itself.
I would suggest calling Kitchenaid Customer Service to see what options are available.
Their toll-free number is: 1-800-541-6390.
Jun 06, 2009 | KitchenAid KFP740 Food Processor
Grater/slicer doesn't spin on my Cuisinart BFP-703 food processor
The gear box spidle operates the regular s-shaped blade as well as the grating/slicing disc. Does the s-shaped chopping/grinding disc still spin? If not, you can get a new gear box. If it does spin, replace the grating/slicing disc - because the plastic may be cracked, as you say. All of these parts are still available from Cuisinart, so I'm not sure why they weren't any help - I've always been able to order from them.
-Tha Mp3 Doctor
Feb 01, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Only toasts one side of toast
The cancel button is stuck in the in position
Jan 13, 2009 | Hamilton Beach 22502 Digital 2-Slice...
I have an ACER 3003WLCi notaebook and there is a CD stuck the CD/DVD drive, how do I remeve the CD/DVD Drvie to remove the stuck CD.
Should be a small hole near button to open drive. Carefully take a paperclip and press slightly in hole. Should eject tray and and you can take disc out.
Be sure that power off and battery/power adapter removed.
Hope this helps!
Mar 24, 2008 | Televison & Video
Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
Kitchen Appliances - Others Logo
55 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
