Question about Garden
My fisher plow wont angle left or right
It goes up and down and when I angle to left it will go up
  • 832 Answers
SOURCE: western snow plow when you try to angle to right
This is a control valve problem. From you comment, it is
clear that the control valve flows to one direction only.
Please check the control valve of the snow plow that
execute the angle to right or angle to left. Also check
the pipelines before and after the valve. It must have a
free flow of the fluid.
Posted on Dec 02, 2009
SOURCE: fisher minute mount goes up and left and locks up
check your connections, especially the main power plug in, i have used a small "c" clamp over the connection to aid in the same problem
Posted on Nov 13, 2010
  • 43983 Answers
SOURCE: I have a 8ft Fisher storm guard plow on my dodge
Duplicate
Posted on Nov 29, 2012
SOURCE: I can hear my fisher plow motor but the plow will not lift or angle
Check/replace under hood motor relay. Spend the extra $2 and get the fisher part. Do not even bother with NAPA junk.
Posted on Feb 02, 2015
dwb13
SOURCE: I have a fisher minuteman plow it will go up, left and right but will not go down what is wrong with my plow
If you have a Minit Mount two it's probably the valve sticking. It's electronically controlled so if it clicks, then the solenoid is working and the shuttle in the valve is stuck. Can be disassembled and cleaned. New ones are best but pricey.
Posted on Feb 07, 2015
Fisher plow angles left only
check your plow to truck connectors some cleaning and some Dielectric grease goes a long way.
when you lose sol. control the hyd. flow defaults to a certain direction.
Make sure they are clean. and lightly greased try that to start.
Feb 08, 2018 | Cars & Trucks
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
Meyers home snowplow goes up n down no problem.angle right it inches its way to the right.angle left motor runs no movement. any thoughts
It sounds like a faulty valve. Some valves use O-rings to seal between ports and they may have failed. I would check the lines for trapped air first.
Oct 25, 2015 | Meyer Home Plow Home Plow by Meyer...
My fisher minuteman 2 plow will go up and left and right but will not go down
Most of those systems don't have a driven retraction on the piston. It is gravity feed back. There is a valve that is sticking or out of adjustment. http://library.fisherplows.com/?cat=38
Jan 24, 2015 | Cars & Trucks
There solinoids on pump. Check wiring and grounds. Make sure all small wires are intact and in good condition. But most likely there's a loose corroded or green wire causing issue
Jan 09, 2015 | Cars & Trucks
I have a fisher minute mount an older model with fixed controls. plow goes up and down but does not go left or right, sometimes with the control set for left or right it starts to go up ? where to sta
check the wiring connections on the plow solenoids to be sure they are correct, the second step is check the controller box, using a continuity check via multimeter set for DC voltage. I have an old western plow that had similar symptoms, and was the controller box.
Oct 19, 2014 | Cars & Trucks
Fisher minute mount plow
does the pressure release close to raise the plow?
Jan 05, 2014 | Dodge Cars & Trucks
Western snow plow when you try to angle to right it goes up does same thing if you try to angle left
Oct 30, 2009 | Plumbing
Fisher minute mount goes up and left and locks up
Oct 29, 2009 | 1998 Chevrolet C1500
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
