I want to delete double down - Audio Players & Recorders
  • kakima Jan 02, 2017
    Hi thomas jeffrey, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    From what?
I would like to remove the double down app from my computer can you help me?
Hi find you're uninstall page when u find double down casino app click it on & delete ...cheers
May 08, 2017 | Tablets & eReaders
Why can't I get on double down casino, it keeps saying that they are upgrading it, but I let it sit over nite and it still says that, please help!!!
If this problem is not solved yet you will need to delete the entire game. Then you need to double tap the Home buttom and delete all of the open apps. Then reinstall DoubleDown.
Oct 15, 2014 | Apple iPad Tablets & eReaders
Garmin dakota 10 does not free up memory
Connect your dakota 10 to your computer ,double click on my computer or computer on deskstop and you will see garmin storage.And then double on garmin F .double click on garmin folder and if you want to delete gpx files click on gpx ,you can see current, archive and track log you've saved.Then you can delete tracklog you've saved .But some tracklog were automatically saved in archive folder ,double click folder and you can delete gpx file.In the same way if you double click on current folder you can see current gpx file and you can delete it.Like that you can delete image file in the same way.One important is you must not delete system files or folder.
Aug 20, 2013 | Garmin Dakota 10 Handheld GPS Receiver
How can i delete skype user name from skype start up page
    • 1 Click "Start," then type "Run" in the search box. Enter "%appdata%\skype" in the "Open" text box and press "Enter" or click "OK."
    • 2 Highlight the folder in the open directory window with the Skype username you want to remove. Press the "Delete" key or right-click and select "Delete."
    • 3 Click "OK" in the confirmation window. The Skype username will no longer be in the login screen drop-down menu.
Feb 02, 2011 | Skype IM
Hotmail.comHello, I would like to be able to find the temperary files and folders that go into my computer automaticly when I browse online.My computer is running very slow and I want it speeded up so if...
hi June here is how you clear the temp file folder on your pc please do this as i say do not take short cuts as you will not get to the correct temp folder.. go to my computer then double click C drive then double click documents and settings then double click on the folder that has the name of your computer on it then double click local settings then double click temporary internet files then in top left corner click edit then click select all then next to edit click file then click on delete then you will have all the internet temp files deleted, i also would suggest getting a very good program called CCleaner this will remove all the junk built up in the registry which is actually the thing that slows pc's down allot, i use it myself and i have found it to be the very best of any pc cleaner about as it does not delete important files from your pc that you do not know what they are about like some other pc cleaners, you can download it from this trusted site http://download.cnet.com/ccleaner/
hope this helps please rate and vote thanks
Sep 08, 2010 | Computers & Internet
I have doubles on videos how do i delete the one
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 29, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
What to take songs off of it
Use the USB connector to link your MP3 player to your PC.
1. Go to start button down in the lower left hand corner of computer screen.
2. Go to my computer and double click.
3. Find the device you want to delete songs from and double click.
(the name of the device should show up on that menu screen)
4. Should a folder come up after you double click do the same to that as well.
Once inside your folder you should be able to delete any music file inside of it by right clicking and clicking on the delete option. To delete multiple songs in this file hold down the Ctrl button on you keyboard and click once on each song you choose to delete. Once you have selected all the songs right click and delete those files.
Side note: When in the list screen (list of all your music) if you click in the view tab up above you can change the way your music files and instead of "icons" you shouold change the viewing style to "list" it will be faster to delete multiple files faster this way.
Happy deleting!
May 14, 2009 | GPX MW3836 MP3 Player
Some songs wont delete
Delete from the Windows desktop if possible. Double click on My Computer. Double click on the icon of the Sansa. Go into the music folder and delete from there.
Or
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Apr 15, 2008 | SanDisk Sansa e260 MP3 Player
Printer locks up
  1. Click Start, Printers and Faxes and double-click on the Lexmark printer driver.
  2. Open the Printer menu and select Cancel All Documents. This will purge the print queue so as to allow the printer to print or uninstall the driver.
  3. If the print jobs are not removed from the queue, click Start, Run, type Net Stop Spooler, and press ENTER.
  4. Click Start, Shutdown, and select Restart. The documents or the print jobs should be removed.
If you are having difficulty deleting the print jobs in the printer spooler, do the following:
  1. Restart the PC in "safe mode". To do this:
    1. Click Start, Shut Down and select Restart.
    2. While the PC is restarting, press the F8 key on the keyboard. Note: Do not hold down the key down, but be aware that you may need to press it several times.
  2. When in safe mode, click Start, My Computer.
  3. Double-click on the (C:) drive.
  4. Double-click on the Windows folder.
  5. Double-click on the System32 folder.
  6. Double-click on the Spool folder.
  7. Double-click on the Printers folder.
  8. Select the contents of this folder and click Delete.
Mar 22, 2008 | Lexmark X3480 All-In-One Printer
Computer "hangs up" when displaying the Polaroid Album in PhotoMAX
This error or system hang-up is usually caused by: 1. the camera driver software attempting to read a corrupted photo; or 2. there are too many photo thumbnails stored in the PhotoMAX temporary storage area. In either case, the problem can be corrected by manually deleting the Fun! Digital 320 camera thumbnails from the Polaroid Album (using the Windows Explorer or My Computer icons). Follow these steps to delete the Fun! Digital 320 temporary files: Step 1 -- Locate the temporary photo files If you are familiar with Windows Explorer, simply browse directly to: C:\Program Files\Polaroid\PhotoMAX SE\Digital 320 If you are new to browsing the file system, follow these steps: 1. Double-click on the My Computer icon on the desktop. 2. Double-click on the C: drive. 3. Double-click on the Program Files folder. 4. Double-click on the Polaroid folder. 5. Double-click on the PhotoMAX SE folder. 6. Double-click on the Digital 320 folder. Step 2 -- Delete the temporary photo files Inside the Digital 320 folder, you will see many files, most of which will be bitmap image files. All of the bitmap files that start with dsc_ (example: dsc_005.bmp) must be deleted. To delete the files, you can either drag them into the Recycle Bin, or highlight each file by single-clicking on it and pressing the Delete key on the keyboard. To select multiple files at once, hold down the Shift key on the keyboard as you click on them, then press Delete. IMPORTANT: Do not delete the following files from the Digital 320 folder: * 320popup.rtf * DscDrv_Polaroid.dll * Polaroid Album.exe
Sep 14, 2005 | Polaroid PhotoMax PDC 3035 Digital Camera
23 people viewed this question
 Grubhead
Grubhead
