Question about Music
Name some best Distortion Pedal. Where to buy them?
    Sergeant:
  • 250 Answers
Try the Boss Metal Zone for serious distortion. As for buying, I use Amazon, eBay and Google searches. eBay is usually the cheapest, and make sure you check the seller's rep. All the online big name shops charge the same. You can go to the different vendor's sites and check sound clips, or find a local music store that does repairs and rents PA gear. The big name stores usually have lousy service.
Posted on May 26, 2017
    New Friend:
  • 3 Answers
The best top 5 distortion pedal are:-
  • BOSS Audio DS1 Distortion Guitar Pedal
  • Pro Co RAT2 Distortion Pedal
  • Boss BD-2 Blues Driver Guitar Effects Pedal
  • Electro-Harmonix Nano Big Guitar Distortion Effects Pedal
  • Electro-Harmonix Soul Food Distortion/Fuzz/Overdrive Pedal
I use to buy any distortion pedal from this site
Top 5 Best Distortion Pedal You Must Buy New 2017 Musical Study as they guide the best to buy the best.
Which is the best site to buy the best Distortion Pedal?
Thes best site to buy a good Distortion pedal is Top 5 Best Distortion Pedal You Must Buy New 2017 Musical Study
You can check all the details about best Distortion pedal in that site. It is available in the best price and a very good quality.
Just go to the above mentioned site and I am sure their review will help to choose the best product for you.
Jan 02, 2017 | The Music
Fulltone Clyde Deluxe wah distorts and interferes with other pedals, along with a narrow pedal range for the effect, though the pedal has a full sweep. I have gotten no answer from Fulltone on the...
The best way to understand the problem source is to minimize the components. In this case, try the pedal alone first. You need to determine whether or not the pedal is causing the distortion. With the pedal alone, how does the system sound/work? Is it acceptable and performing as expected? If so, then the next step is to add one more effect in the chain. Try the effect BEFORE the Fulltone first. Does the distortion appear? If so, then the problem is likely in the input stage of the Fulltone. It should be able to handle mic level inputs. The effects you are using should be outputing the same level as well. If you are unsure of the output signal levels of the effects, set the guitar to a fixed level and insert one effect at a time. The overall signal level should be similar for each one at the "unity gain" setting.
Please try a few options as suggested above one at a time and report the results here inas much detail as you can. This should help to resolve the problem.
Dan
Mar 15, 2011 | Fulltone Clyde Deluxe Wah Effect Pedal NEW
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Will this amp have metal distortion if i add a distortion pedal
The amp can accept most anything you can get out of a distortion pedal. If you play it too loud you can damage any amp.
I would HIGHLY recommend you either take your amp to the store where you are buying your pedal and try it with your guitar before buying.
ALSO don't forget to get a power adapter as the pedals "eat: batteries.
May 02, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
When i turn on my pedal i can get the clean tone but when i switch the distortion i cannot get the distorted sound...what should i do?
Make sure the pedal has the correct power supply voltage, current AND polarity.
Also adjust the setting knobs as needed.
Make sure the in's and out's are corectely connected... it will work clean if they are backward, but no distortion.
Mar 11, 2010 | Boss Mt 2 Metal Zone Effects Pedal
My BOSS Distortion(DS-1) pedal buzzes whenever the distortion is up. I've changed the battery, outlet, and amp, but it continues to sound. I tried a different pedal, and it worked fine. How can I stop it...
This sounds like a broken ground wire or trace within the unit if an IDENTICAL pedal does not act the same AT THE SAME SETTINGS.
Sometimes a circuit trace gets broken on the board inside pedals and can cause this.
Since an identical pedal doesn't have the problem, service is required.
If you know electronics you can open the pedal and look for obvious problems.
HINT: Use a bright LED penlight to "candle" the circuit board to look for cracks.
Look for broken solder joints... this can take an experienced eye to spot.
A distortion pedal NORMALLY is very simple circuitry.
Nov 08, 2009 | Boss Music
Constant hum/buzz only when the distortion is turned up. Otherwise works fine. Already checked cables. Please help.
Distortion is a very HIGH gain operation and any hum on the input will be amplified many times.
Check your guitar AND input cable for ANY hum at all at high gain settings on the amp WITHOUT the pedal in line to assure that the source is not before the pedal.
ADDITIONAL cause could be a poor power adapter for the pedal or even a bad filter cap in the pedal.
Nov 02, 2009 | Boss Mt 2 Metal Zone Effects Pedal
I need the operation manual for a Danville tec80G guitar amplifier. I also need to find out where I can get a footswitch for this amp. I would like to be able to incorporate some sort of distortion...
Well,its a real obscure amp.No company website from what I can find.
Here is a review of the amp though on a good tab forum:
http://www.ultimate-guitar.com/reviews/guitar_amplifiers/danville/tec80g/index.html
As for the footswitch dist.pedal,you have a few options.Look on the back of the amp and see if there is A)an effects loop.This may say "return" and "send" and you can hookup a pedal through that to bypass the input jack.Then just plug in normally to the front of the amp.Also check to see if there is a 1/4 input on the back that may say "footswitch".If so,fender makes a button footswitch that comes with most of their middle of the road combo's.This plugs in just like a guitar cable and will switch your channels.
If you need a recomendation on a distortion pedal go with MXR.Its a little morre expensive(by $10.00 maybe),but its the best bang your gonna get out of a pedal.
Sep 21, 2009 | Music
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Music Logo
41 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
