Question about GE Home Security
I have a GE peacekeeper alarm security system but the voice doesn't work. It beeps every 30 minutes. How can I fix the voice command?
  • Maria Tenfee Jan 02, 2017
    Thanks but I'm talking about the, "voice". Chime work and will beep but voice won't say center 1 back door open... I cleaned it I believe after that,bit stopped. I barely touched the box with a soft cloth.
    Top Expert:
  • GE Master
  • 45,018 Answers
The voice response may have failed
  • 78 Answers
SOURCE: Westinghouse Security System beeping
Hi, as you know your system is old. The company that made your system no longer exists. There is no support for your system. No parts available. It sounds like a circuit board problem. Defects in circuit boards are not normally fixed where I work. Not cost effective to pull panel and send it out to be bench tested. shipped back for reinstallation. cheaper to replace panel and keypads. There is a 50/50 chance you may have to replace sensors Too, on that panel. Hope this helps.
Posted on Sep 09, 2009
  • 5 Answers
SOURCE: GE simon security system
Depends. Do you mean the chime? If all that is missing is the chime whenever a zone is tripped then simply press the CHIME button on the front panel. If it is lighted solid red then your chime is on and it will talk to you. If chime is off then it wont talk to you at all when a zone is tripped. Good luck.
Posted on May 19, 2008
  • 54 Answers
SOURCE: alarm wont sound
If your door is protected by a wireless transmitter your problem is most likely a defective switch or a grounded wire from the switch to the transmitter. To determine if the transmitter is working properly pop off the top of transmitter case by using a small blade screwdriver. If you look on the side of the casing you will see a small slot where the screwdriver is placed. Insert the blade of the screwdriver there and twist. The top of the transmitter will release. Inside you will see a small circuit board and battery. If an external switch is used you will also see 2 wires connected to the circuit board which then leads to the swtch. Using a very small screwdriver remove these wires. Now go check system status at your keypad. If the system recognizes the door as open then your problem is a bad switch or pinched wires that are grounding out the switch. If the keypad's status says the door is still closed the problem is in the transmitter. Sometimes these transmitters will be installed using an internal contact/switch.To know if this is the case on your door you will see only the transmitter mounted on or next to the door and a small magnet within a half inch or so on the opposing side. If this is the case your problem again is the internal switch. For replacement of external switches you can try going to a Radio Shack where they offer an assortment. Hope this helps.
Posted on Apr 05, 2010
  • 54 Answers
SOURCE: low system battery
While I am not familiar with the brand name of your security system all systems use a backup battery in the event the electric power goes out in house. When electric power is on the system automatically trickle charges the battery so that it is ready for use when needed. If your system has a control panel (normally a white metal box found in a 1st floor closet or basement) where all the wiring to the system has been run, open it and you will see the battery which is connected to the control panel's motherboard with red and black wires. Most security system batteries are rated at 12 volts DC and are sized at either 4 amp hour or 7 amp hour. Make a note of this and go to a battery warehouse store in your area and have them match it up. Once installed a battery should be replaced every 4-5 years. If your system does not have a control panel (some systems are portable) then the batttery could be located in a console. Most of these types of systems have a battery access area from the rear and are much smaller than ones found in control panels. Usually these are 12 VDC 1.5 Amp Hour. Hope this helps. If there is anything unusual about your system that I have not addressed please get in touch with me and I will try to answer your questions.
Posted on May 25, 2010
  • 74 Answers
SOURCE: ge simon 2 alarm no longer beeps after battery replaced
Probably knocked off the clip on the piezo. Open the box and make sure all plugs are plugged into the circuit board.
AlarmProfessor.net
Posted on Aug 23, 2010
To turn the beep sound off when system is set to armed
Troubleshooting FAQs - Solve Problems Quickly by ...
www.adt.com/help/faq/troubleshooting
The ADT CorporationHow do I silence low battery beeping? ... Why is my ADT Pulse security systemreceiving an unavailable message? ... How do I fix a disconnected camera? ... by a motion detector while the system is armed, the burglary alarm will sound. ... Some common events that may cause a motion detector to set off a false alarm ...
Five Steps: How to Stop a Beeping Security System
https://www.vectorsecurity.com/.../Five-Steps-How-to-Sto...
Vector SecurityFeb 9, 2015 - The shrilling sound of a continuously beeping security system is enough to drive anyone crazy. A power outage, faulty wiring or bad batteries ...
The Top 15 Questions about ADT Home Security Systems ...
zionssecurity.com/...security/the-top-15-questions-about-adt-home-securi...
Oct 10, 2012 - How do I turn off the voice descriptions but keep the chime sound on?... If your time on the Lynx system is not set all you need to do is push your user code + # + 63. ..... When our security alarm is not armed it beeps every few seconds ....Reasons to Install Security Cameras in your Home · Small Business ...
Jan 03, 2016 | Home Security
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
Getting status message "module 1 failure"
Contact me and I will tryto walk you theough your problem.
Alarmprofessor.com
Jun 24, 2010 | GE Security Simon 3 Wireless Home Security...
Ge simon 2 alarm no longer beeps after battery replaced
AlarmProfessor.net
May 20, 2010 | GE Security Simon 3 Wireless Home Security...
I can get the cell back up to work on my simon 3
The vell module is not like a cell phone. It is specifically set up to go to the alarm.com network. You need to have an alarm company involved. Alarm.com can send you e-mail or tect messages if you have a smartphone, but you are going to be about $25-$30 per month to get that service.
Alarmprofessor.net
Mar 05, 2010 | GE Security Simon 3 Wireless Home Security...
It beeps about six times every four hours,why?
Hi, press the "status" button for details on your problem. If it does not tell you press twice. do not remove this system till you talk to alarm company, if you have one, to place system on test. So police dont show up. Also you want to know if you are still under contract with them.
Jul 04, 2009 | GE Security Simon 3 Wireless Home Security...
System Low Battery Alarm
You can silence trouble beeps by arming and disarming the system or by pressing status button; however, trouble beeps resume after 4 hours if the trouble condition as not been fixed. You can turn the trouble beeps off in the programming option 40. This should be done by your security professional because any mistake you could change other parameters in the system and the system may not work correctly. Hope this helps
Aug 19, 2008 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
97 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
