I have an Onkyo TX-SR607 and I can't get my XBOX HD DVD player to play. I can get the xbox to play but when I select play HD DVD the screen goes blank. I played the HD DVD on another TV so I know it works. Help???
SOURCE: onkyo Remote Controle Codes for XBoX 360
There should be a code on your remote index for DVD Player XBOX
Posted on Mar 30, 2008
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
Gurudristi
  • 98 Answers
SOURCE: onkyo tx-sr806 reciver ''DTS HD''
hdmi connection between player and AVR. Right?
I am sure you would have also done the first time setup and set all the 7 speaker as well as the subwoofer thru your auto or manual speaker set up and that the reason you are getting Neo6.
On your Receiver, please also check the format of the digital input signal thru "Displaying Source Information" Press the [RECIEVER] button, and then press the [DISPLAY] buttorn repeatedly to cycle thru the available information.
a).. If the information shown say that DTS - ES Discrete, DTS- Matrix, DTS -HD and so on.... then we need to check as to why the receiver is not accepting the signal.
b).If the information shows otherwise and a 7.1 signal is not availalbe, then its possible that the source(in this case the BD player/or the recording is not sending the required signal).
lets take the case (a). In this case if you have all the 7.1 set up in place and you are getting the required signal , then you can assign a default listening mode to each input source that will be selected automatically when you select each input source.
Press [RECEIVER] button followed by [SETUP] button and enter listening mode setup, use up , down buttons to select the input source that you want to set and press [ENTER].
then use [up], [down] button to select the signal format that you want to set.
then use the [[LEFT] and [RIGHT] buttons to select a listening mode.
When you are finished, you can press [SETUP] again.
The above is with experience with ONKYO AV Receivers. In case you have a problem , please let me know so that I can go thru the SETUP menu of your particular receiver i.eTX-SR- 806.
HOpe the above sort out. DO let me know.
Please do rate this solution and thanks for using FixYa!
Posted on Mar 05, 2009
  • 4 Answers
SOURCE: connecting a wii to an Onkyo TX-SR607 7.2
I am experiencing issues like this although with a VCR connected with analog video. I added a BluRay DVD player and all of a sudden I lost my video upconversion from my VCR. I am going to try to reset the receiver to see if this fixes the problem. If not, I don't think it is the receiver issue, I think it may be the fact that enorder for video to pass through HDMI, allot of criteria needs to be met. Certain Handshakes need to happen, especially with the HDCP issues. Most likely I will connect a separate video cable to my Plasma and use a secondary input on the Plasma for the VCR signal. You may want to purchase the Component Video adapter for the wii system as this will provide you with at least 480p and your receiver should not have an issue passing the signal over the HDMI output. Good luck and give me an update.
Posted on Jun 17, 2009
  • 1126 Answers
SOURCE: Is there any way to program my Star Choice URC550
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=starchoice
This is the only model that I could find. Codes are in the back of user guide. Hope this helps.
Posted on Aug 23, 2009
We are having HDMI handshake problems between our Onkyo TX-SR607 and our Sony KDF-55WF655 LCD Projection TV. The problem is intermittant. Sometimes it comes up just fine, and other times the screen is...
Hello, I am sorry for your issue. Haw long is the HDMI cable from the receiver to the TV? Have you tried a different cable/ Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-SR607 Receiver
Lost colors when using composite cables with Wii
puedes subir o bajar la resolucion de tu t.v o pantalla ya que algunas son HDMI u otras FULL HD probablemente no este bien ajustada o los cables no estan funcionando bien o estan trozados,....
May 02, 2010 | Onkyo TX-SR607 Receiver
Powered sub only has sound while watching a dvd or listening to music on Onkyo TX-SR607
So perhaps it's a source sound issue. THAT would best be investigated at the Dish receiver. Consider it's audio settings and how it interfaces with the Onkyo.
Apr 25, 2010 | Onkyo TX-SR605 Receiver
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
No video output from Onkyo receiver
Hello, I am sorry about your issue. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 10, 2017 | Onkyo TX-SR607 Receiver
Connecting a wii to an Onkyo TX-SR607 7.2
Jun 06, 2009 | Onkyo TX-SR606 Receiver
Hd-dvd-player
Just go to your memory on your xbox dashboard and delete the transformers cookie. If you do not know which one it is just delete all the HD DVD Content files and start fresh. When you are done and you put the Transformers HD DVD in again, it will ask if you want to accept the cookies. Simply select "decline cookies" and your problem will be solved. It make take a minute to load the movie, but this fixes the problem
Nov 04, 2007 | Microsoft Xbox 360 Console
134 people viewed this question
 Grubhead
Grubhead
