Question about HP Computers & Internet
Monitor is dark in hp dv6451 laptop; attached monitor lights the startup screen then goes dark too. what is the cause/repair/fix please
SOURCE: monitor problem.
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Posted on Oct 26, 2007
djnick989
  • 1067 Answers
SOURCE: hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Posted on Jan 29, 2008
CNC65
  • 15 Answers
SOURCE: HP Pavilion dv2000 laptop won't
HAVE YOU TRIED (SAFE MODE)? & WHAT O.S. ARE YOU USING?
Posted on Nov 06, 2008
farhangM
  • 64 Answers
SOURCE: Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Posted on Dec 02, 2008
ComputerGirl
  • 85 Answers
SOURCE: dell inspiron 5150 dark screen, faint image in background
ah, change the backlight it is most likely dieing
-CG
Posted on Jan 23, 2009
A125 monitor is dark
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Toshiba Satellite Computers & Internet
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
Feb 08, 2011 | Computers & Internet
Hp laptop screen black at startup
Hi
I assume the fan is whirring and you have some lights/LED's glowing. If you look around the sides and back of the laptop you will see a blue VGA socket. Plug a spare monitor into this blue socket, philswift.jpg You may need to use a friends monitor to test it out. If it still does not show an image on the monitor, make the laptop change where it is sending the picture. To do this press 'fn' (function) and hold down. Then press one of the 'F' keys that has a picture of monitors on it. In the photo it is 'F4' philswift_0.jpg
Keep pressing 'F4' whilst still holding down 'fn' as this may scroll through many monitor options. Leave 5 seconds between each press to let the action happen. If you still do not get an image then the laptop monitor graphics card has failed. If you do get an image on the spare monitor but not on the laptop screen then you have a failed backlight or inverter. Angle the laptop and catch the light and see if there is a very feint image on the monitor. It looks very dark but you should be able to pick out what you would normally see. If you can see this very dark image it is the backlight. If you cannot it is the inverter or the LCD screen itself. From here on we are into professional level fault finding, you can see here http://www.daileyint.com/hmdpc/lcd.htm . If the laptop was old and slow it may not be worth repairing. If you do wish to go ahead and reapir send it off to a fixed price repair shop like http://www.sefton-computer-repairs.co.uk/screens.htm or myself at www.tecorum.com It takes a few days to repair and send back.
All the best, Phil
Dec 04, 2010 | Computers & Internet
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
The monitor screen lights up, then goes dark.
I assume that you get the same symptom when you hook this up to another PC. You will need to open it up and check the fuse, solder connections, etc. Please see pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 24, 2010 | Dell E152FPc 15" TFT LCD Flat Panel...
My notebook is showing a light dark sreen but its working fine the only problem i cannot see well sinse the screen is dark when i bring it close to the light i can seen but not clear.thanks
Have you adjusted the brightness? Amend where necessary
Does it happen even on startup? Yes = Monitor Failure repair/replace. No=Graphic settings
Oct 30, 2008 | HP Computers & Internet
My power comes on my laptop but screen is dark
First, Plug in an external monitor.
Press <FN> <F4> to toggle between lcd and external monitor to see if it will light an external display.
if that does not work...check your numbers on the bottom against this list. HP knows of flaws on the DV6000X. I loaned a friend a laptop so he could send his in for repair. If the number matches your laptop you are eligible for free repair.
Apr 30, 2008 | HP Pavilion dv6000z Notebook
Hp laptop wont restart
please connect your laptop to external monitor.
if it works with external monitor, then the problem is with your laptop monitor driver.if that is the case, then re-install laptop monitor drivers.
if it doesn't work even with the external monitor, then re-install graphic card drivers.
Apr 05, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
