Question about Refrigerators
Boscn fridge freezer top freezer part working bottom fridge part not getting cold
  • 454 Answers
The port in the back of the freezer is frozen shut. You will need to unplug the refrigerator, empty the freezer, and remove the back panel to expose the coil. You may also want to remove the tray in the freezer floor. Melt all of the ice with a hair dryer so air can be blown into the refrigerator again.
While melting the ice, check that the water is draining through the port under the coils. If not, this port needs to be thawed as well, otherwise the ice will block the ports again.
When everything is dry and the water drains again, reassemble the freezer panels. Plug in the refrigerator and make sure the freezer fan runs. You should be able to feel air blowing into the refrigerator compartment if you hold your hand in front of the port. If the fan does not blow, you will need to troubleshoot and possibly replace it.
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
Fridge not getting cold
With a top freezer the cold air comes from the freezer down into the fridge. It uses a fan to blow the air down. It's possible that the fan is burned out. Does the fan come on if you turn the temp. to the fridge to colder? If not, then that may be the problem. The fix is not too easy, but can be done by an experienced do-it-yourselfer.
Mar 11, 2012 | Electrolux ER7926B Bottom Freezer...
Bottom freezer left open overnight. Freezer does not work anymore. Top fridge does not getting cold as it should be.
Your fridge gets it's cold air from the freezer. If the freezer is not working then the fridge won't get cold.
May 26, 2011 | Refrigerators
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
