Question about Home
Handle on my fuildmaster 400 toilet - Home
Fluidmaster 400 manual
Why is the water leaking out of the tank? There's only reason for that, the water is slowly leaking by the plunger.check the plunger aT The bottom of the tank it's activated by the handle.shut the water supply off empty the tank,clean the bottom of the plunger refill tank .problem should be fixed if not replace plunger.. Happy plumbing.
Sep 01, 2014 | Fluidmaster Water Saving Easy Fix 400...
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
Toilet handle sticks
It sounds like the nylon nut which holds the handle in place is too tight. Try loosening that nylon nut just a little to see if the handle moves easier. Sometimes if they are over-tightened, the handle will be stiff and hard to operate.
Apr 10, 2014 | Home
How do i fix a loose toilet handle
remove the lid and behind handle there will be a plastic nut tighten by hand
Oct 11, 2012 | Mansfield Plumbing Products Mansfield...
When I flush the toilet the handle stays down and therefore the toilet runs on. How can I fix it?
If you lift the lid you should see where the handle goes through the porcelin. You can remove the handle by unscrewing the nut inside the tank. Try cleaning the inside of the nut as sometimes water deposits collect in this area and cause binding on the handle shaft. After you clean it up you can apply a very small amount of petrolium jelly to the handle shaft when you reinstall it, this should prevent the problem from happening again.
Jun 09, 2011 | Kohler Toilet - One Piece with Ingenium...
It will not flush properly .rudy
How to Troubleshoot a Flushometer
A flushometer consists of a metal pipe extending from the back of a toilet with a slender handle on the side that is used to flush a toilet. This type of flush valve is commonly used for toilets in commercial facilities to provide a durable and accurate flush delivery system. If the flushometer does not work properly, troubleshoot it and perform minor repairs. Common issues are often resolved quickly. If troubleshooting does not correct the problem, call a plumber for repairs.
Does Not Flush
1 Inspect the handle assembly. A broken handle or assembly will prevent flushing. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it with a handle repair kit
2 Open the main water supply valve to turn the water on fully. The water supply is normally turned on, but check to make sure it is turned on fully and has not been turned off inadvertently
3 Remove the flushometer's CP cover, the round cap on the very top of the pipe extending from the toilet. Then remove the inside cover directly underneath the cap. Inspect the relief valve. Replace it if it is visibly damaged.
Short Flush
1 Remove the CP cover and inside cover. The CP cover is located on the very top of the pipe extending from the back of the toilet. The inside cover is underneath the CP cover and the diaphragm assembly is located beneath the inside cover. Remove and inspect the diaphragm assembly. A damaged diaphragm assembly can cause a short and incomplete flush. Replace it if it is visibly damaged.
2 Replace or repair the handle assembly. A damaged handle can result in a short flush. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it using a handle repair kit.
3 Remove the CP cover and inside cover to remove the diaphragm assembly. If a low consumption diaphragm is installed on a water-saver fixture or a urinal diaphragm is installed on a toilet fixture, replace it with an appropriate diaphragm.
Mar 04, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Handle for toilet
Pegasus Plumbing co.
2455 Paces Ferry Road
Atlanta, GA 30339
888-328-2383
May 18, 2010 | Pegasus Technologies Two-Piece Round...
Tilet want flush no pressure when depressing
Take off the top lid and look at the flush handle mechanism. You'll see a not that holds it onto the tank. Tighten the nut so it is snug. Don't overtighten it or you could crack the tank. Next inspect the chain that goes between the end of the flush handle rod and the flapper valve. It should lift the flapper all the the way up when you operate the handle.
Apr 11, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Toto toilet ultra max flush
Open the tank and examine the linkages between the handle and the flapper. If the handle is sticking, it sounds like there may be either mineral buildup or a stuck chain.
May 27, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Home Logo
85 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
