Tv flickers with no volume until warmed up then restarted
2 Suggested Answers
SOURCE: my sony xbr5 flickers until warmed up
brennanrp, I hope you purchased a warranty on your TV. My 46 in xbr-5 was doing the same thing. I called the store I bought it from and they took it to a repair shop. The panel inside, basically the inner workings are faulty and Sony has put an extended warranty on it. Get it looked at as it will only get worse. Soon you will probably be seeing some vapor like images across the screen if you have not already. the lines starting showing up even after extended viewing times.
Posted on Jan 29, 2010
Sony pfm-42x1 flickering screen when turning tv on
OKAY I found the Problem!! Bad Caps Compositors. I Proved this in 2 ways. First I took off the Back(always make sure the TV is UNPLUG) In the photo above I put my finger on the capacitors. I found some that where NOT FLAT ON TOP(You can kinda see in the photo too). I could feel a little nipple on top.(Some times you can see if their busted open but not in this case) so I felt them and the bottom right and top left area in red in the photo where not flat. I took my dryer(My wife really) and warmed them up for about 2 minuets each then another minuet rotating back then forth. I leaned the t.v. up to lean on the frame and plug it in. I continued warming the capacitors up and in about 2 Min the T.V. has stop blinking. Much better then the 20-30 min. So the hunt for the Capacitors is on. It will be some work to get the boards out. If everything is done delicately The Soldor job is easy for me. I am going to buy the 8 but replace 1 board at a time until the TV works and put the other on the side for next time or put them up on E-bay. I hope this helped Please like if this helped you. ea0a96a3-fb82-4ec0-89f4-76b4080e9c6e.jpg 1b190ebd-5d69-4553-a009-840d29ab4c87.jpg ab9b51d0-6e1d-4cce-b822-e80d0fde9163.jpg
Oct 13, 2013 | Sony PFM-42X1 Plasma TV
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
I have a Hitachi 50GX49B, when I turn it on red light on panel comes on, but no picture or sound. 4 weeks ago picture would come on, but would break up and dissappear until warmed up, this took about 2-3...
if you bang on the TV or try kicking the very center bottom of the tv and it works or flickers you got a loose solder connection somewhere on the board. I got the same problem. When it warms up the solder, around what ever pin it might be, makes better contact. I am looking into the problem and will post my finding when i figure it out.
Sep 02, 2010 | Hitachi 50GX49B 50" Rear Projection...
When i switch my tv on. I can hera the volume but no picture. Then the tv switches off and restarts until both the volume and picture is working. This could take up to an hour
yes. tv has a circuit which controls current to the red, green, and blue piture tubes. you wont get picture until they are balanced. adjust the screen controls until it comes on faster. it should only take maximum 20 seconds for a picture. gaurantee it will fix it. adjust the screen control
Nov 09, 2009 | Toshiba Televison & Video
My sony xbr5 flickers until warmed up
Oct 14, 2009 | Sony Televison & Video
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Dash dials flicker when cold and are ok when engine warms up or after 20 mins
hello,seem you have a loose contact in your engine temperature,ty
Apr 25, 2009 | 2000 Mercedes-Benz M-Class
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
