Question about Bemis Humidifiers
My humidfier the bemis 696 400 is running alll the time but not using much water
Fan and water does not work
What brand and model do you have for starts. Sounds like a low voltage power issue.
Feb 24, 2015 | Aprilaire 700 Humidifier
My homedic s humidifier is leaking.I turn it on in the evening and next morning I see it in a puddle of water.Happens every time.
Chances are it is just condensation not leakage if it's only wet when its running. Nothing you can do except put a towel under it.
Dec 01, 2014 | Homedics Cool Mist Humidfier - Uhe-oc1 -
I have Bemis (Esswick) Humidifier Model # 4968. The motor runs fines however I can't get the humidity in my above 30%. I changed the filter and it was close to 45% for a few days but running continuously,...
You should be able to get a higher humidity rate at normal settings. If you want high humidity above 40% that should be easily done with the high speed operation. The unit may need a good internal cleaning, and use a Vinegar solution to clear any Calcium or other mineral deposits from the misting ports and misting elements. You must use only Distilled or Filtered water, not tap water.
Jan 29, 2018 | KwikFilters.com Bemis 4968 Humidifier Wick...
I bought a hunter humidfier about 2 years ago and now i am using it for the first time. I took all the plastic off around it and opened up the top to make sure the filters and everything is in place. I...
Hunter carefree humidifiers use a reusable and washable wick this method of humidifying does not produce a fine mist like many centrifugal (cool misting)humidifiers. The fact that it is producing cold air seems to indicate it is working. However it would not hurt to check the water intake for blockages it also a good idea to run these models on high for several mins when starting this ensures that water is being pumped up.
Mar 07, 2011 | Hunter CareFree Plus 33222 Humidifier
I have a Honeywell humidfier HE 220A with a KIP U147112 pump. A lot of water bypasses the humidifer and I use 5 gal. in 24 hours. is there an adjustment on the pump to reduce the flow, or some other...
I have a Honeywell humidfier HE 220A with a KIP U147112 valve. Will turning the large screw head on the valve decrease the volume of water flow through the humidifier. Too much water is being wasted.
Dec 20, 2010 | Honeywell HE220A1019 Whole House...
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
No water flow to the humidifier
Turn that pin to the left and that will open the valve to allow water to flow through it. If it starts to leak the all you need to do is tighten the nut that were the water is coming out with a wrench, be carefull it wont take much to tighten.
Dec 02, 2008 | Aprilaire 600 Humidifier
Moisture not coming out
i realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Jan 20, 2008 | Bemis Whole House Digital Humidifier ED11...
Bemis Water Wick 6974Tanks will not disperse water properly
sounds like new caps should solve it, but have you tried soaking the old caps in vinegar overnight? these guys are not the only ones, but they have the correct caps in stock at a pretty good price http://www.marbeck.com/humidifier_parts_bemis.html hope this helps :)
Mar 14, 2007 | Bemis 697 400 Humidifier
Humidifiers Logo
96 people viewed this question
Top Bemis Humidifiers Experts
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
