Question about Cuisinart Coffee Makers & Espresso Machines
Both lights on the hot water side blink. In a 2 blink cycle for each one? Is it time to ckean?
  • B Hung Jan 02, 2017
    It is the Cuisinart coffee maker plus model
2 Suggested Answers
  • 4 Answers
SOURCE: Dishwasher 66516039 won't run very long and the
Need to know make and model
regards, service gnome
Posted on Jun 15, 2010
Why does my dishwasher stop during cycles and the cycle light blinks?
it has few functions , so break them down to this.
does water flow in correctly . hot an cold
does the pump re-cycle water well inside . reflow lots of spray.
then does it pump out correctly an flow easily into garbage disposal , check the back flow valve for stoppage if it has one {its in the large plastic pipe right before the disposal.lets water flow but compactor garbage is blocked, it sticks a lot closed }
and is the door latch secure test it by opening suddenly is all you can do.
you might have to open the door quickly to check these items like spray or pumping.
Aug 03, 2014 | Whirlpool Gold Dishwasher with Quiet...
How do I reset my delonghi ec860
my coffee machine is not working,,, the water ligh is blinking green n not doing anything.. anyone can help with this?
May 18, 2012 | DeLonghi EC Coffee Makers & Espresso...
Clean light blinks seven times and will not start on any cycle.
The problem you are having is that the dishwasher is sensing that the water is not getting hot enough to finsh out the cycle. The first thing you need to do is get the dishwasher into diagnostic test mode, you can do this by pressing: normal wash then heated dry, 4 times. After in diagnostic mode you can exit out by pressing cancel/drain. This will get rid of the blinking clean light and the washer can be operated in any cycle now. To prevent this light from coming back on, you can do one of two things. First you can just try running Hot water at the faucet before each time you use the dishwasher. Or, you can replace the thermistor/sensor that senses the water temperature. You can purchase this part at this link http://www.repairclinic.com/Sensor-Or-Thermistor-Parts?s=t-DU1055XTS-%3d%3dc61
Nov 27, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Kenmore dishwasher clean light is blinking and now wont wash dishes what can i do?
try this and make sure you water is hot enough to cycle your washer, as it has a temp. sensor for this.
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
Oct 20, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
When going to wash with my GW11 it stops during the was cycle and the cold and hot water light blink and the machine beeps
Hi just read your posting.Now, when the hot and cold lights flash at the same time it means that you are not getting enough or no hot or cold water.Remove the cold and hot inlet hoses from the machine end and put the ends into a bucket.Now turn the taps on to see if you have water coming out the hot and cold hose and if the water pressure is adequate.Try a cold fill on the wash cycle and see how it goes.please reply and let me know if there is water coming out of the hoses at a good pressure and also what water temp do you select on the wash cycle.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Clean light wont stop blinking
This is a code that the water is not being heated. this could be caused by a bad heating element, lack of water, computer control problem or an inadvertant error. all things involved with heating the water need check. the computer has to be reset using a diagnotic mode. wiring info usually behind toe panel may help to solve the problem. please include model # if further info needed.
Mar 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The clean light is blinking on the dishwasher. i
if its flashing 7 times. make sure hot water 120degree goes in unit. if water is satisfied then replace heater and main board. its a kit
Feb 09, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Clean light blinking will not start
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Apr 06, 2009 | Whirlpool 24 in. GU2500XTPS Stainless...
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
