Question about Keurig Coffee Makers & Espresso Machines
My Keurig will not turn on. I hAVE UNPLOGGED, PLUGGED BACK ON, STILL NOTHING.
I have a Keurig 2.0 when you plug it in the power button comes on, on the lcd screen but when you touch the power button nothing happens. It won't turn on. Any suggestions. Thank you.
Found the below from this site: http://coffeestylish.com/keurig-problems/
Keurig 2.0 won't turn on
To turn on your Keurig 2.0 plug in the brewer, then press and hold the power button (the power icon will appear in the bottom right corner of the touchscreen). You should see a welcome! note. If it doesn't turn on you can do few things:
Check to make sure that the brewer is plugged securely.
Unplug and plug in the brewer.
Plug the brewer into a different outlet.
As a last step, Keurig even recommends resetting your home's circuit breaker just in case.
If nothing works, then you should definitely call Keurig customer service.
Jan 24, 2016 | Computers & Internet
Won't prime
The water pump system is not primed properly. Remove the water tank while the pump is running and put back a couple of times. If not working, when the power is off, using a straw, blow air through and try to **** through the water port at the bottom of Keurig. Plug the water tank again in and start the system. It will take some time to prime, keep trying. There is nothing wrong with the machine, but the water pump circuit.
Oct 18, 2012 | Keurig Elite B40 Coffee Maker
My Keurig B60 stopped working - I plug it in and nothing happens. Prior to this, it was leaking and lights were blinking
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 17, 2011 | Keurig B60 Coffee Maker
My Keurig will not turn on...no lights flashing, nothing...I used it two days ago and it was fine...i came back into work and it wouldn't do anything. I tried unplugging it and leaving it unplugged and...
heatman101
Sep 15, 2011 | Keurig Elite B40 Coffee Maker
Will not turn on. Worked fine this morning, came home and power light was out unplugged unit and then plugged back in, nothing. Any helpful info for the power issue?
heatman101
Aug 01, 2011 | Keurig Elite B40 Coffee Maker
The keurig is plugged in and will not turn on. there is power at the outlet. When i trigger the switch in the back of the machine nothing happens. Is there an internal fuse?
heatman101
Jun 14, 2011 | Keurig B60 Coffee Maker
My keurig will not turn on at all its a elite b40..plug it in press the button and nothing happens
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
Nov 15, 2010 | Keurig Elite B40 Coffee Maker
TV is not working anyore
maybe stupid but try to plug-unplog from power outlet.. does it make any sound? kliking sound? if nothing helps than your starter is gone.
Apr 28, 2009 | Panasonic PT-60LCX64 Television
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
