There is power to the stapler, no power to the motor?
Error Code E000532-0002
The stapler shift motor (M4) or
the stapler shift home position
sensor (PI7) is faulty. There is a
fault in the path of the stapler
Dec 03, 2013 | Canon imageRUNNER C3200 Copier
Tip
ERROR codes Canon 6045
Canon 6045 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace, same possibilities as E000. E003 Fuser temperature drops. Same as E000. E004 Fuser problem: AC driver, SSR bad, wire shorted. E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this. E006 Fuser feed connector. E010 Drive problem. Main motor, gears, etc. E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times. E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller. E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller. E030 Total counter. E031 Option counter or total counter. E050 Holding tray (duplex) home position sensor motor or board. E051 Holding tray (duplex) home sensor motor or board. E202 Panel locked up, but might be no code, scan motor problem. E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem. E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor. E402 RDF belt motor or pulse sensor. E403 RDF feed motor or pulse sensor. E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motorE522 Sorter push bar motor E523 Sorter reference wall motor E524 Sorter multi-guide motor E525 Sorter bin paper sensor automatic adjustment problem E526 Sorter bin paper sensor automatic adjustment problem E530 Sorter guide bar motor E531 Sorter stapler motor E532 Stapler motor E533 Stapler inside paper sensor E540 Sorter bin shift motor E550 Sorter power supply E710 DC controller E711 DC controller E712 Document feeder IC failure E713 DC controller, sorter E800 Auto power off circuit problem. Main switch or DC controller. E802 Auto power off circuit problem. Main switch or DC controller.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4835
Canon 4835 E000 Low fuser temperature E001 High fuser temperature E002 Low fuser temperature E003 Low fuser temperature E010 Drive E030 Counter E080 Color change board problems E081 Color horizontal motor problem E082 Color horizontal motor problem E083 Color problem in vertical direction E084 Color problem in vertical direction E085 Color problem in vertical direction E086 Color unit claw release problem E089 Color change incomplete E100 Laser problem E110 Laser motor problem E140 Laser unit E203 Scan drive problem E210 Lens not home or won't leave home E240 DC controller E401 Document feeder pick up motor E402 Document feeder belt motor E403 RADF feed motor E404 Document feeder motor E411 Document feeder sensor E500 Sorter to DC control interface problem E510 Stapler/sorter motor E530 Stapler swing motor E531 Stapler swing motor E540 Sorter bin motor E541 Sorter bin motor E710 DC controller
E000532-8001
E532 Main cause Stapler shift motor (M10) Stapler shift home position sensor (P16) Detection The stapler shift home position sensor does not go OFF when the stapler shift motor is driven for 4 sec. The stapler shift home position is not detected when the stapler shift motor is driven for 4 sec.
Sep 29, 2012 | Canon imageRUNNER 8500 Copier
HAS CODE E532 AND MESSAGE TO TURN OFF AND BACK ON
E532-1 Stapler guide bar motor E532-2 Stapler swing motor E540-3 Bin shift motor
Apr 01, 2010 | Canon NP 6545 Copier
Wath can i do,if the machine Canon Image Runner 9070 send the follow error message: E000532-0001
Nov 16, 2009 | Canon imageRUNNER 8500 Copier
Hi sir......i have minolta machine 1080......i want to cancel the mark of toner....how?...plz..
Minolta 1080
C000 Main drive problem C001 Main drive speed. Too fast or too slow C004C Fan motor problem C004E Power supply fan problem C0070 Toner motor drive problem C0071 Toner motor speed. Too fast or too slow C010 Drum motor drive problem C011 Drum motor speed. Too fast or too slow C0400 Exposure lamp does not turn on or AE sensor problem C0500 Low fuser temperature during warm-up C0510 Low fuser temperature after warm-up C0520 High fuser temperature C0600 Scan motor drive problem C0610 Lens motor drive problem C0620 Mirror motor drive problem C0990, C0991 Main tray up problem C0992, C0993 Main tray down problem C0994 Elevator motor problem C0996 Main tray shift problem C0998 Tray shift problem C0999 Tray shift return problem C099A, C099b Shift home problem C099c Shift drive motor C0b10 Auto exposure sensor problem C0b11 Paper clamp motor C0b30 Paper aligning motor C0b31 Paper aligning motor C0b50 Stapler motor C0b51 Stapler problem C0b52 Stapler sensor C0b60 Sorter bin motor C0b61-C0b64 Sorter bin movement C0d00 Duplex rail sensor sensor problems C0d20 Duplex home sensor C0d50 Duplex drive motor problem C0d51 Duplex drive motor speed C0F10 Auto exposure sensor problem C0F30 Paper aligning motor C4100 Exposure lamp stays on C0F79 Paper empty sensor problem
Sep 13, 2009 | Office Equipment & Supplies
The problem in canon 6050
this error from sorter/stapler unit if this problem is repeated
disconnect the sorter and use copy tray,sorter must be serviced
E530
Main Cause The alignment plate home position sensor (PI6) is faulty. The alignment
motor (M3) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The alignment plate does not leave home position when the alignment
motor has been driven for 2 secs.
0002 The alignment plate does not return to home position when the
alignment motor has been driven for 2 secs.
E531
Main Cause The stapler home position detecting switch (MS7) is faulty. The stapler motor
(M6) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The stapler does not leave home position when the stapler motor
has been driven for 0.5 sec.
0002 The stapler does not return to home position when the stapler motor
Jun 06, 2009 | Canon NP 6050 Copier
E532-0001
An E532 happens when the stapler unit either does not move from front to rear, or rear to front, or hangs up and stops part of the way. A broken stop gate can get in the way of a stapler and keep it from moving. Usually the two inside gates are the problem. The bottom spring may have fallen off when the plastic tab on the bottom of the gate (which holds the spring) breaks off. Or the parts of the gates that come in contact with the white rollers on the stapler assembly become dry and need to be greased to allow the stapler to slide past them. Also check the wiring harness that runs from under the stapler, through an opening and then connects to the stapler itself. Wires have been known to break internally at the wire-tys and cause erratic E532s. Check each wire with a meter for continuity. Hope this helps a little.
Jun 06, 2008 | Office Equipment & Supplies
k24674
