Question about Plumbing
Does this pump have a reset button and where is it located for this cast iron unit
  • kakima Jan 02, 2017
    Hi james a hood, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "this pump"?
2 Suggested Answers
electrodynam
  • 35 Answers
SOURCE: what type of grids are the best and why, either
The porcelain is easier to clean,and wont rust,but it can also be chipped off if dropped.Its really a personal choice after that.there is nothing wrong with the plain old cast iron ones.
Posted on Jun 07, 2009
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
Knocking compressor
really depends on the model of compressor but if it is an oil less compressor best thing is to junk it and buy a oil lubricated with a cast iron pump dont get one with aluminum if you want a compressor to last you for many years.
Mar 19, 2014 | Hitachi Air Tools & Compressors
On the obd2 Diagnostic Tool the code 21 showed Oxygen sensor circuit problem volts too low so where is this sensor located
The sensor is located on the exhaust system between where the cylinder ports enter the common manifold and the muffler. Sometimes they are on the cast iron manifold and sometimes they are on the exhaust pipe after the cast iron manifold.
May 13, 2013 | 1996 Jeep Cherokee Country
What are the advantages of a cast iron wok?
when cast iron woks are seasons properly, they help create the special 'wok style' flavor. They also have good heat retention and cook the food evenly.
Feb 18, 2013 | Home
I have a PUMA air compressor that has been running fine until this morning, it will not run, I have power (220 ) to the wires at the pressure switch and the reset button was not tripped, motor and...
If you remove the fan belt and the motor runs without a load,
one of your motor capacitors is bad. some motors take one
capacitor, some take two. the capacitor is what helps the
the motor give that extra torque to run the compressor pump.
good luck!
Jul 17, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
Compressor will not turn on
some air compressors have a lever on the pressure switch to turn off unit, check the contacts in the pressure switch, I have found mashed insects between the contacts on some I've repaired
Aug 16, 2010 | Campbell Hausfeld Single Stage Air...
Quit working...is there a reset button?
the reset button should be on the elec motor,it should be red.if it was leaking air you most likly have a bad checkvalve .it screws into the tank where the airline goes in also.replacments can be had at tsc.
May 19, 2010 | Campbell Hausfeld 5.0 Hp Cast Iron Air...
1/3 hp wayne pedistal sump stoped working
yes there are brushes,, but there is also a shaft that goes thru the tube make sure it is not broke or bent,, it happens,, suggest to get a zoeller submersable pump its the best cast iron, float is attached to the unit, will fit in small pits, only 1 plug needed,, cost for pump 100
Dec 31, 2008 | SPV Wayne Pumps Spv500 1/3hp Cast Iron...
H Burner replacement
There are aftermarket cast iron burners available for approx $64.95. Otherwise, the OEM burner is a Dynachrome which is a chrome plated cast iron that is almost $300. I do not believe that the cast stainless is still available.
Jul 26, 2017 | Dynasty Grilling
Plumbing Logo
130 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
