How do I clear error 38 - Office Equipment & Supplies
  • kakima Jan 02, 2017
    Hi anthony kamau, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
Memory error 38
Hi Anonymous, error 38 is battery voltage high. Good luck
Jan 10, 2014 | Harley Davidson FXSTD Softail Duece...
Has error message 66 and 38 model IW812
Hi - Code 38 is pressure related: remove the rear top corner (2) screws, locate the clear tube with a clamp on, blow into it away from the the controls, insert & try again.
Under no conditions do you blow pressure into the transducer or the electronics end - it will damage the unit.
The problem with the washer is that the motor controller has sensed the lack of water in the machine as so to speak, hence the error.
Code 66 - is also the same issue as code 38. Worst case scenario you need to replace the motor controller module.
Jun 17, 2011 | Fisher and Paykel Washing Machines
My Mitsubishi WD-73734 TV will intermittently just shut down- no picture, no sound, the set just turns off. When I check the TV for an "error code," I am able to identify error code # 38. What...
38 Lamp temperature abnormally high. Poor Air Circulation - found in service guide at - http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf
Dec 17, 2010 | Mitsubishi WD-73734 73" Television
We have a an error 38 on brother intellifax 5750 laser fax - I can't find the manuel. How do I clear it?
menu *2864 in quick succesion, should flash and say test mode, press either 091 or 91, and then try 099 or 99 to return to main screen
Jun 02, 2010 | Brother IntelliFAX 5750e Laser Fax
Problem installing broadcom netxtreme gigabit NIC in windows server 2003 R2 standard, the driver doesn't load, error code 38
Determine Correct Driver Click Here
1: Uninstall any unwanted programs.... (make sure/Try to Clear your Hard Drive more than 50% as free)
2: Update virus software
3:Restart Computer IN Safe Mode
4: Run Virus Scan
5: Restart in Safe Mode
6: Uninstall Existing Driver Software From Device manager
7: Restart computer in normal mode
8: Start>Run> type %temp% and hit run.
9: Delete all files in this folder....
10:Restart Computer
11: DEFRAG
13: Restart COmp.
14:Install Driver
>Troubleshooting for Error 38
The error message for this error appears as: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory."
This error occurs when a previously loaded driver is preventing the new driver from loading. To fix this error follow these instructions.
  • Reboot Your PC
  • Open the Device Manager and in the device Properties box, select the General tab.
  • Properties Uninstall(Right Click Mouse) / Disable(In Property)
  • Restart PC
  • reinstall /enable
  • Once you have followed the instructions throughly, reboot your PC
Hope this make you Better Conclusion....Thanks for Using FixYa.....
Apr 21, 2010 | Computers & Internet
System error 010023 00000001 and macanical problem
010023 – Is a EEROM Test failure error
Try the following to get it straighten;
Clear the EEROM and turn the printer off and on again from the back of the printer. If after clearing the EEROM the error disappears, make sure you perform the calibration back up.
If we are not sure how to perform the above steps, please visit the manual from the below thread Page 38 ;
http://www.feedroller.com/Store/Service%20Manual/DESIGNJET%201050C,%201055CM%20Large%20Format%20Service%20Manual.pdf
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | HP DesignJet 3500cp InkJet Printer
Error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 07, 2009 | Xerox Phaser 8500DN Printer
MFC-620cn fax-2440C error 38
The only way to solve a Machine Error 38 is if there is an item/broken paper inside the machine that you can actually reach. Judging by the sound your machine seem to make, I'd rather guess that you got a mechanical error on your hands, which would require the machine to be sent to service to have it solved. Check for bits of paper or other loose items, otherwise - service.
Jun 02, 2009 | Brother MFC-5860CN InkJet Printer
Xerox Phaser 8500DN printer error : 09,037.45:67244
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
Mar 05, 2009 | Xerox Phaser 8550DX Laser Printer
Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
Nov 10, 2008 | Microsoft Windows XP Professional
22 people viewed this question
jasbo
jasbo
