Question about Timex 27191 Wristwatch
My solar powered 50-lap Ironman died after 1 month of normal use! Now it just stares blankly at me until I press any of the buttons, in which case it goes back to 12:00 and works for a couple of minutes just to humor me, before going dead again. Any tips?
I have exactly the same problem with my solar powered Casio watch.
I discussed it with a good jeweler and he explained that when you have sun, the watch 's battery will be charged up. But when the battery's charge is used up it works off a capacitor power source. But if the capacitor is defective(no available backup power) you then end up with a blank display. And it'll display the default settings(12:00) for a while only.
You can have a jeweler change the capacitor to get it working again.
For my $100+ watch, it'll cost me about $25 to replace the capacitor.
But for yours, the watch may not have cost that much and therefore
be hard to justify that cost.
I hope the explanation was not too technical for you. Good Luck.
Posted on Aug 15, 2009
Hello , I own a timex iron man triatholon model no t5g691 , the problem is none of the buttons work . they only work when I press them all together to turn it off . I also went recently swimming with it...
this problem occur only if one of the buttons are stuck inside, because you cannot push two or more buttons at the same time unless that you have to reset the watch. 2nd probably the buttons of your watch didnot reached the contact inside, sometimes it needed to be cleaned and had to be lubricated. if still did not work. reset your watch using the reset button inside the watch. i hope this will help you a lot.
Sep 13, 2011 | Timex Ironman Triathlon Solar Powered...
How do i turn off the hourly beep on my timex ironman t5k160?
press and hold the upper left button which is set, the seconds blinks then press the mode button/the lower left button until it reaches the chime turn it off pressing the middle button once. if your done press the "set" or upper left button. i hope i had been helped you.
Aug 10, 2011 | Timex IRONMAN Triathlon 50-Lap Mid T5K160...
I just need online instructions to use the lap timer on my Women's Timex Ironman Triathlon watch. I'm not sure of the model, but I think it's a 50-lap, and it's small. The 4 buttons on the side...
Here is the link that can help you set up your watch. Also here is the All list of timex watch downloadable instruction.
I hope this can help you resolve your issue.
Thank you for choosing Fixya
Mar 06, 2011 | Ironman Timex T5B721 Sports 50 Lap...
How do i change from the time after daylight savings
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please .
Apr 07, 2010 | Timex 5J261 Solar Powered Ironman...
How can i recall multiple laps during a run?
The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
Sep 17, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
I cannot set anything on my timex ironman watch.
I fixed it but don't know exactly what I did. I think I pressed the mode (upper left) then the button on the lower right side to change the hour. But I'm not so sure. At least I didn't have to have my son do it for me.
Dec 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Getting my digital watch to stop beeping every hour
i think the battery is low voltage,try to change the battery 1
Aug 25, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Indiglo button kills watch function
I have the same problem with my watch. I replaced the ML-2016 battery myself. (which I found at Walmart) But when I press the iniglo button, it just stops the clock and I have to press the start/split button to get it to resume. No idea how to get the problem resolved
Aug 19, 2008 | Timex 5J261 Solar Powered Ironman...
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
Dec 10, 2007 | Timex Sports Ironman Triathlon 50-Lap...
Timex 27191 Wristwatch Logo
111 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
