Question about Dishwashers
My Currys Essential CDWTT10 table top dishwasher is overfilling, its continues to fill until water eventually leaks out of the machine.
Im guessing its something to do with the float? How easily is it replaced, Thanks
3 Suggested Answers
SOURCE: Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Posted on Mar 16, 2009
  • 528 Answers
SOURCE: Our Kemore dishwasher is leaking water onto floor,
you just need to clean the pump area in the bottom of your unit :)
try to take spray arm out if you can and then open pump cover clean it good but watch for broken glass in it ...and thats it :)
Posted on Jan 01, 2010
Electrolux EI24ID30QS Dishwasher over fills, and eventually trips the float in the tray below.
That float switch is sticking, a common issue. Do this, pull the float and shaft out and reinstall several times to free up the micro switch that turns off the water supply valve.
May 01, 2017 | Electrolux Dishwashers
I need a user manual for a currys essentials cdwtt10 dishwasher
Feb 04, 2013 | Dishwashers
My currys essentials cdwtt10 dishwasher is showing an error code E3?
Feb 25, 2012 | Dishwashers
Hi, i've taken the top and sides off my Bosch dish washer sgs45e02gbas it has not been working. the problem is ....when you switch it on is there is a pumping/throbing noise but doesn't continue...
Hello Phillip,
The reason only the pump runs anytime its powered up is because the flood detector has detected water in the base of the dishwasher and until that water is gone only the pump will run.That flood detector is (when looking at it from the front) is in the left front corner,its a styrofoam disc with a rod in the center of it and has floated up activating the flood switch on the letf side wall where the water enters the tub (can be seen on the left side with side panel removed) if thier is no water in the base frame perhaps some foreign object has wedged itself under the sytrofoam disc holding it up. Until the water is out of the base frame only the pump will run as long as the flood switch is tripped.
Possible things that will make water be in the base frame are,
oversuds from too much detergent
a leak of any component or hose
a defective water level switch allowing it to overfill
Sep 06, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
When left the dish washer slowly fills with water causing flooding
If the dishwasher fills when being left off, the tech must check for voltage at the inlet valve, then eventually replace the inlet valve.
If the dishwasher overfills during cycle, then test and eventually replace the water level device, usually a float sensor and switch.
Dec 02, 2009 | Bosch Dishwashers
Our Kemore dishwasher is leaking water onto floor, and the water valve continues to pour water when machine was turned off, but is not leaking water now. There is also standing water at bottom of tub from...
Aug 12, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 | Dishwashers
Indesit dishwasher overfilling
There are two ways that dishwashers generally fill. One is a float inside the tub, the second is a tube which fills with water, loops and goes to a pressure switch below the machine. That switch is usually about 1.5 inches in diameter, two wires and a small hose going to it. The float witch is found below the float in the motor area. With the float, sometimes they jam with too much old detergent or food goo. Clean out. Both can have the switch weld closed. Change the switch in either case. Since the unit is not filling with the power off, I'm going to guess the water solenoid is okay.
Dec 22, 2007 | Dishwashers
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Cimbali M 29
One thing to check... Have you switched to 100% reverse-osmosis or distilled water recently? I read that the water level probe needs conductive ions (e.g. calcium) in the water for it to detect that water has risen to the probe's level. So, water with too few ions will not register on the gauge, and the tank will continue to fill.
Apr 24, 2007 | Espresso RMI La Cimbali Espresso Machine
Dishwashers Logo
Top Dishwashers Experts
