Question about Candy Washing Machines
How to change drum bearings in candy cmd146 washing machine
Hi, does anyone have a service manual for candy cmd146 washing machine? or can you tell me how to change the drum bearings in it
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
  • 38 Answers
SOURCE: candy drum bearing replacement
if you are absolutely sure it is the bearing, you will need a special tool to pull the old one off and press the new one on. My advise is to have a professional repair person do the job.
The Candy front load machines have a three-pronged support at the back for the drum. This sometimes get cracked or broken, when this happens, you will have to replace the entire drum assembly as the support is riveted on to it.
The broken support causes the inner drum to rub against the outer tub, giving the impression that the bearing is bad.
Posted on Jun 15, 2008
barkencoa
  • 3463 Answers
SOURCE: Need a User Manual for Candy CMD146 Type LCE2
Hello.
I can direct you to the site you need to download a copy of user instructions for your washer dryer.
In your browser bar, type -
hoover user manuals
In the drop down list, click on-
hoover after sales service-instruction manuals
Then click on -------laundry
then click on --------washer dryers
In the box enter your model, and you can download the instructions.
Pleas a fixya rating for my solution to your query..
Thankyou.
Posted on Jan 30, 2009
SOURCE: Main Drum Bearing
Rear Main Bearing is bad, Believe you have replace whole back of the drum, about 200$
Posted on Apr 02, 2009
  • 152 Answers
SOURCE: Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
Posted on Feb 26, 2010
My washer makes grinding sound when washing, how do I fix this?
Guess it's a bearing in the drum, though just my appreciation. If you are not a tech in washing machines, you should call a reapir service to get it dismounted and replaced
Watch some videos about issue. Take note that you are not specifying your make an model and procedure might be somwhat different for your particular washing machine.
How to change drum bearings on washing machine
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Bosch Neff Siemens and some...
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Aug 12, 2015 | Washing Machines
Belt for CMD146
you will need to replace the brushes in the moter ok
Oct 18, 2012 | Candy CN146 Front Load Washer
Cmd146 dryer heating top chamber but not in drum
It sounds as though the fan motor is faulty, usually these motors distribute the heat from the heater box into the drum. Because the heater box is getting hot I doubt if the fault is the thermostat so it may well be the motor or associated wiring
Mar 29, 2017 | Candy CN146 Front Load Washer
How do the drum caseing come apart to change bearing on my candy go1482 washing machine
Candy GO1482 model is made by Hoover and the drum is welded shut. You can't replace the bearings (cost usually 10 GBP) and a replacement is 220 GBP plus vat. I've just been bitten and hurt badly over it. Next time buy Indesit, Hotpoint or Bosch.
Aug 10, 2011 | Washing Machines
Instruction manual required for candy smart cmd146
How do u turn the heat down when drying clothes?
Jan 12, 2011 | Candy Washing Machines
Candy grand o not spinning when loaded
Kindly replace the motor to solve your problem
May 17, 2010 | Washing Machines
Machine candy washer dryer cmd146 will not start after repeating pushing the start button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Mar 18, 2010 | Candy CN146 Front Load Washer
Hello.
hoover user manuals
Thankyou.
Jan 30, 2009 | Candy CNW156 Front Load Washer / Dryer
Candy CMD146 Washer/Dryer
This machine has selfcondensing system. The condense water is beeing pumped out with the cooling water. The watertap MUST be open during drying. It also may be caused of overloading. The most W/D combos is just able to dry just the half of a full load in one time.
Jan 10, 2008 | Candy CN146 Front Load Washer
Candy cmd146 washer dryer
more info. i.e is it pumping out water????
Dec 05, 2007 | Candy CN146 Front Load Washer
Washing Machines Logo
545 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
