Question about Hotpoint Washing Machines
My Hotpoint dwf30 won't fill with water - Hotpoint Washing Machines
  • Hotpoint Master
  • 5,323 Answers
Check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
Posted on Jan 05, 2017
Hotpoint hswp1000m washer cycle fills with water for large capacity but when it goes to rinse it won't fill anymore than low capacity of water?
It can be due to a faulty water level sensor which evidently is a pressure switch. If the diaphragm is damaged it will require a larger water level to achieve the said pressure to shut the inlet valve in all the cycles.
Jan 12, 2013 | Hotpoint HSWP1000M 3.5 Cu. Ft. Capacity...
WASHER WON'T FILL WATER
Check to be sure the drain line is higher that the tub of the washer. You have a siphon going on the drain.
Nov 05, 2012 | Hotpoint Washing Machines
Hotpoint dishwasher dwf30 washing as normal but no heat
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 24, 2010 | Dishwashers
My hotpoint aquarius dwf30 will not drain so will not wash...
Do you hear the motor run or is there deadly silence when you select drain.
Does the wash cycle start - do you hear water getting in and washer arms move?
Are there any lights flashing?
Jul 06, 2010 | Hotpoint 24 in. DWF32P Free-standing...
Where is the element on a Hotpoint Aquarius dwf30 dishwasher?
It sits in the base of the machine and you would need to remove the complete top section of the dishwasher to gain access to it, which involves removing the door first, then the balance weight and finaly the stainless steel top section
Mar 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hi i have a dwf30 for some reason all the items are coming out with lots of grease marks on them the tablet pops out ok as you can hear it but everything seems as if its not been rinsed out i thought it...
is there any strange rumbling or moaning coming from the drum ??? if so the oil and greace may be from the back bearing due to the bearing oil seal becoming faulty allowing water through to the bearings
Feb 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door gasket.as far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Oct 24, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Washing Machines Logo
48 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
