Question about Pioneer Car Audio & Video
I have a pioneer DEH 150 radio it's loses its memory when the isolator switch is turned off in the tractor?
When the isolator switch is turned on the memory of the stations is gone?
    Top Expert:
  • Pioneer Master
  • 43,997 Answers
The radio has been wired incorrectly so no 12v battery power is applied to retain memory when the isolator switch is turned off.
Everytime i turn off the car it resets all of my settings pioneer deh-150 mp how do i fix that
There is a wire not hooked up to Constant power so you have no memory In the Radio. The Yellow wire on this unit is the constant power and needs to be hooked to 12v. Hope this helps.
Sep 30, 2014 | Pioneer Deh150mp Cd/Mp3 Car Receiver...
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
How do you get the Pioneer DEH-P670MP car stereo cd player off of mute?
hi there
to fix this press and hold the source button till unit turns off the source button switches from CD - radio...................once your unit powers off........press and hold the function button down till the clock appears in display you should also hear a beep when this happens.........press the function button repeatedly until the telephone feature appears now switch by pressing the skip button to ATT (Attention) once this is done press the source button to power on the pioneer unit simply turn up the volume and problem should be solved......
hope i was able to help
Feb 21, 2009 | Pioneer Premier DEH-P670MP CD Player
Memory not working
blue yellow to yellow and gray to red should be right
Feb 01, 2009 | Pioneer DEH-2300 CD Player
Memory not working
you may not have hooked up the extra wire for the memory back up on the radio... it will stay live when you shut off the radio.
Robert
Please take a moment to rate this solution thanks
Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
Sep 16, 2008 | Pioneer DEH-1700 CD Player
Setting my stations on my Pioneer DEH-27mp
the yellow wire on the radio's harness must be connected to a 12 volt line that has power regardless of the key switch position, If not the radio loses its "Memory" every time you turn off the key
May 06, 2008 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
Car Audio & Video Logo
60 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
