Question about Elite Home Security
This Q206 board replaces the master-board in the elite gate opener
4 Suggested Answers
  • 52 Answers
SOURCE: when should I replace battery for Elite Robo-slide gate opener.
Sounds like its time to replace now!
Posted on Jul 02, 2009
  • 68 Answers
SOURCE: We have an Elite Sl-300 gate opener that will not
if you take the covor off the unit and look at the motor their is a redbotton. press that back in and tru again
Posted on Jan 13, 2011
benmdavid
SOURCE: I have an Apollo 636
Apollo slide gate opener closes when remote is pressed, but does not open when remote is pressed again. I think it's a 7100 series. I think it needs a reset, but vacant find any reset button on the board
Posted on Dec 11, 2013
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
Eagle slave gate not opening with master
Switch leads for master and slave to see if its a wiring issue. if the same gate fails to operate, it may not be your controller.
Jul 05, 2014 | Elite Sl 3000 Ul Sliding Gate Operator
Charging LED does not light up. transformer send 19VDC to plug on board. battery drains
In my case, I solved this issue by replacing the Surge Suppressor. I was measuring 19VDC where the transformer connects to the surge suppressor but not at pins 2 and 4 on the connector to the control board. If "transformer send 19VDC to plug on board" means you are measuring 19VDC at connector pins 2 and 4 (or pins 2 and 4 on models that have a terminal strip instead of a surge suppressor), this answer doesn't apply.
Jan 11, 2011 | Elite Q206 RoboSlide Control Board
My elite operator will only close part way, seems to only happen cold nights 52 degrees-F works well in the day time no matter the temperature, limit switches checks out ok, I disconnected the loop...
You will have to increase your force (sensitivity) settings on the p.c. board. Without knowing what type of board you have I can only guess. There should be a pod you can rotate with a screwdriver to increase the force. If it has an LCD readout with menus search the menus for force or obstruction, then increase it.
freddy51
Feb 08, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Strike open light flashes and gate opens
it was a loose connection on the circuit board in the romote keypad
Sep 30, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Holiday Programming
the elite does not have that function, your are going to need to look for a time clock that holds open your gate...... the outside phone system or a programmable time clock that has been added to your gate...... oh this is an old post sorry. :)
Dec 19, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Home Security Logo
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
